Question about Intel ASUS P4C800-E Deluxe 875P Socket 478 DDR 400 ATX Motherboard 3-in-1 Combo (MP4C800EDLXCOMBO)
I have a motherboard P4C400-E DeLuxe serial no.: 3CMG019473 and oneof the components has suffered overload and broken down. I would like to know where I can gethold of component specifications and connection diagram, and soldering temperature allowable for the component.
    President:
  • 2,666 Answers
It will be cheaper and quicker just to replace the MoBo.
Posted on Sep 01, 2010
Does intel g43t-dm1 motherboard support ZOTAC NVIDIA GeForce GT 630 Synergy Edition 4 GB DDR3 Graphics Card
It depends upon the total wattage of all components in your computer.
If you do not know how to add up the total wattage of the components in your computer then just install the Nvidia graphics card.
If the switch mode power supply is overloaded it will automatically shut down. Then you need to install a higher wattage power supply.
Mar 27, 2013 | EliteGroup ECS G43TDM1 Intel G43 Socket...
CPU keeps overhreating.
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Feb 24, 2013 | ASUSTeK COMPUTER ASUS P8Z68 DELUXE/GEN3 -...
I just want to know whether SATA 1TB hdd support Asus K8V SE Deluxe Motherboard or not? and also i want to use 512 MB grafix card. can both things support to this motherboard?
Yes as long as there are SATA ports on the motherboard it will work fine.
You will need to find out if your graphics card is pci-e or agp and make sure it matches the motherboard.
May 03, 2011 | ASUS K8V-SE Deluxe Motherboard
Followed advice from "Ulangreg"...still have
It appears the motherboard is faulty. When the power supply is overloaded it will shut down. You have confirmed this by by removing the eatx connector and it powers up again.
Mar 02, 2011 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Is there a serial number on a the motherboard itself? I have asus A8N-SLI deluxe that is not putting out any display. And need S/N and dont have the box it came in.
You do not need the serial number to download the video driver, but you need the motherboard number, this is printed on the motherboard.
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Dec 16, 2010 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
Change of serial number (BIOS, motherboard)?
The serial number is encoded in the CMOS chip. You will have to see if ASUS provides a utility. ASUS is a great company and I am sure they will be able to asist you.
Apr 27, 2010 | ASUS P5B Deluxe Motherboard
Need a manual
You can find the manual along with all the other down loads for that motherboard at http://support.asus.com/download/download.aspx?modelname=P5LD2 Deluxe&SLanguage=en-us
Oct 30, 2009 | Ld ASUS P5LD2 DELUXE INTEL 945P CHIPSET...
Motherboard not starting Bios but fans start
Yes, had exactly the same problem earlier this week, the bios chip may be faulty, as you know all other components work, so it's down to the motherboard and a replacement is required
Mar 22, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Asus A8N-SLI Deluxe Problems Booting
Sounds like the power supply is overloaded. Is this a new configuration? Start removing components until it powers up. If it still doesn't power up, check to ensure you don't have a short in any of the connectors that you installed components into. Sometimes when a video card, memory DIMM, or whatever, gets installed, there is a chance that a connector pin will get crushed and short out to nearby pins. If none of those work, you might want to try a larger wattage power supply. Good luck.
Nov 24, 2006 | ASUS A8N-SLI Motherboard
Intel ASUS P4C800-E Deluxe 875P Socket 478 DDR 400 ATX Motherboard 3-in-1 Combo (MP4C800EDLXCOMBO) Logo
119 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
