Question about Parmak Solar Fence Charger
We need to replace the part that holds the fuse on the Parmak 6 volt solar charger DD-SP-SS. The fuSe broke off in the holder and it won't come out. Is there a replacement fuse holder available for this unit? If so, can you send us a link to order one?
3 Suggested Answers
  • 76 Answers
SOURCE: I just bought a Parmak 6 volt solar electric fence
I WOULD THINK SO BUT THE BLACK MAT BE THE POS. AND YOU MAY BURN UP THE CHARGER IF HOOKED UP WRONG BUT OTHER THEN THAT YOU HAVE GOT I THINK
Posted on Jun 24, 2009
BillB-SA
  • 2761 Answers
SOURCE: installing instructions
You can download and print your PARMAK manual here:
http://www.agfence.com/fence/Assets/documentation/parmak/InstallationManual.pdf
Posted on Dec 19, 2009
I have a paramark solar charged fence model number df-sp-li it dosen't click anymore how come? Is the click important
The click is the transformer carrying current. If the unit doesn't click, unhook the fence from it and turn it on. If it starts clicking it is a short on the fence. If it doesn't then the unit is not working. contact parmak and they can service it or sell you a replacement circuit board which is the most common failure.
Sep 24, 2012 | Parmak Solar Fence Charger
No charge, is it battery or solar panel, how do I tell
if the unit is not produceing a charge during daylight then it is the unit. the DF-SP-LI will produce full power under sunlight alone. test the unit with the fence unhooked.
Jun 01, 2012 | Parmak Solar Fence Charger
I have a Parmak Model DF-SP-LI. With a volt meter it reads 2.3 on the fence, but the performance meter is always reading beyond the green.
It depends on the type of fence tester. the common light-o-meters are a resistor ladder, calculated not only for voltage but current. the DF-SP-LI uses half the lowest current most are designed for. no if that is a digital or analog meter, then it would be time to check the out put from the charger with out the fencer connected. if you get the same reading it maybe defective unit. if you get a better reading then you will probable need to upgrade your ground system. insuffencient ground will show its self as a low out put on the fence but not on the charger.
May 20, 2012 | Parmak Solar Fence Charger
Model DF-SP-SS unit has been out of servicer for quite a while, stored in the dry and in the dark. The output from the solar cell is 8.6 VDC. With a new battery installed and left in the sun for several...
theses symptoms would say that your circuit board has/is failing. in particular the 25tts 12 SCR. you can contact Parmak for either parts or service.
Jul 14, 2011 | Parmak Solar Fence Charger
I bought a Parmak Solar Pak 6. I wanted to use it
when you touch the wire, you are probably wearing shoes, which ground you,
touching it barefoot or kneeling on bare knees should provide a bit more jolt.
take your multi-meter, shove one probe in the ground and touch the wire with the other and you should get a nice reading
May 08, 2010 | Parmak Solar Fence Charger
HOT LEAD FROM SOLAR PANEL HAS A ELECTRICAL COMPONENT WHICH IS BROKE. WHAT IS IT? (6-V)
Either a voltage limiter (because a solar panel can put out upto 21 volts.... BUT more likely a diode - which prevents the storage batteries from discharging through the solar panels (power goes only INTO the batteries when the diode is working.
Radio Shack will be able to match it if you remove it and take it to them.
Jan 21, 2010 | Parmak Solar Fence Charger
Installing instructions
Dec 19, 2009 | Parmak Solar Fence Charger
Parmak Solar Fence Charger  Logo
Top Parmak Electrical Supplies Experts
Craig Butler
Craig Butler
Steve Pack
Steve Pack
Are you a Parmak Electrical Supply Expert? Answer questions, earn points and help others
