No water is going from the tap to washing machine
  • Washing Mach... Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Sep 01, 2010
Machine wont fill with hot water
problem in hot water tap
hot water solenoid not activating to let water in
to prove either switch the hoses on the taps and press cold water wash
that proves the tap
then press hot wash and that proves the solenoid
Jul 21, 2016 | Fisher and Paykel Washing Machines
I have a LG Punch WF-C5856TC washing machine. Off late, Notice that the water is trickling in rather than flowing. Hence it takes really really long time to wash clothes. Pls advise
The first place to look is the inlet tap in the wall
even you have the tap on full the tap washer inside jams and prevents the full flow of the water
next check out the filter in the hose at the tap or at the washing machine end
next replace the water inlet solenoid
you can check this by changing the hose from the hot water tap onto the cold water tap and pressing the hot water button to fill
solenoids do not know the difference , they just work when the power is applied
Sep 08, 2015 | LG Washing Machines
I need to wash the colors in cold water ONLY but when I set the washer on cold, it still washes clothes with warm/hot water for part of the cycle, causing the colors to bleed. How do I need to set it up...
G'day, simple solutions is to swop your hoses at the back around, you can do this at the taps... If you only have one hose going into machine, you need to make sure the hose is on the cold water. Some new machines heat water internally, hence they don't need hot water going in at all. Sounds like you are putting hot water only into your machine. If you only have a hot water tap in your laundry for washing machine, this cold be a problem as the machines don't cool down the water. If this is the case you might have to look at other plumbing solutions... Hope this helps, let us know how u get on
Aug 08, 2011 | Washing Machines
Water hammering after disconnecting a washing machine. I have just replaced our old washing machine that took a hot and a cold feed, with a new washing machine that only takes a cold feed. I have turned...
You can use a water hammer arrestor and hook it up to old washing machine hot valve by use of a standard washer hose. This type of aresstor is basically. a shock absorber. You will needtonget pipe adapters to go from hose thread to pipe thread.If you can mount the hammer arressror higher then the washer valve. Hook everything up and turn old hot water valve back on. This shoulg take care of your problem. Thank you.
Jun 02, 2011 | Plumbing
I have water leaking into the washer when it is turned off. It is a steady drip that is coming from the water hose. What do I need to do to fix this?
Hi just read your posting.If the water is coming into the machine when it is not being used then one of the water valves is faulty.There are 2 ways to rectify this. The first is to turn your taps off to the machine after use and this will stop any water going into the machine until you turn the taps on again when you are about to use the machine for washing and the second way to fix this fault is to change the water valve or valves.If you turn the taps off it will save you money but if you decide to change the valve, reply back and I will guide you step by step in the replacement of the valve.Looking forward to your reply.
Aug 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
Error code PF
The answer above is from Washerhelp. Here's the full diy help from Washerhelp regarding advice about a washing machine not taking in any water http://www.washerhelp.co.uk/diy-repair-help.html
Nov 04, 2009 | LG WM-2277HW Front Load Washer
I've just moved house and my machine is not
Hello Friend, I think your machine will work properly if you add a water line splitter. You would connect to the single cold water tap and on the other end you would have two water hoses . Connect one hose to the cold water inlet of your washer and then connect the other hose to the hot water inlet. You can get these at Home Depot. Happy to help, Tim.
Jun 29, 2009 | Whirlpool Washing Machines
No water is coming in the washer before the agitator starts
The above answer is copied from Washerhelp Please only use small quotes and link to the original source
Mar 29, 2009 | Whirlpool Washing Machines
Washing Machines Logo
Top Washing Machines Experts
