Question about Pioneer PDP-425CMX 42 in. Plasma Television
Cables I have a plasma (pioneer) and lost the cables. not outlet but video cables. Please let me know what cables to buy so that i can watch my tv
What you need for this Plasma will be a HDMI to DVI cable and maybe a specialty Component to SVGA cable. This plasma has the SVGA in and Out ports as well as a DVI port. The other thing to consider is if your plasma has the upgrade card that will also accept RCA component and S-Video. If you don't have the upgrade card, I would highly recommend it. This is a great monitor!
Posted on May 14, 2009
    Novelist:
    Champion:
  • 216 Answers
Greetings 4mother,
It would really depend on what type of hook up you are using. Most of the time a plasma television would be hooked up with either and HDMI or component cables. Your local store should be able to make a solid recommendation based on the items hooked up to your television such as cable or satellite box, dvd player, etc.
I hope this helps.
Thank you,
Dorothy
Go Ahead. Use Us.
Posted on May 15, 2008
Just moved and rehooking up the plasma. Plasma does not turn on/has no power. Cable box plugged in, power cord rechecked to ensure plugged in correctly and checked power cord it has 110/120 at the plug...
Check that the outlets "GFCI" fuse or reset button hasn't been triggered. If this isn't a GFCI outlet, then verify the breaker is on. If still no luck, verify the device input power i.e. 110/240V
Sep 26, 2017 | Pioneer PDP-6020FD 60 in. Plasma TV
Hi .. need to connect my tv audio through my pioneer 5.1 home theater.I was using normal video audio cable ...shall i use component cable???pls advice
"Component" cable refers to the 3-wire hi-def video connection. It's irrelevant to audio.
Assuming you get all your TV programming through a cable box...
The TV wouldn't actually be a source of audio.
I would advise you to route the Cable Box's BEST DIGITAL audio directly to the Pioneer model number ????? (which would be helpful to know for this conversation).
Run the cable box's normal analog audio to the TV so you can watch it without the Pioneer turned on.
And route the best Cable Video (HDMI, Component?) directly to the TV. Unnecessary paths through the receiver can degrade the signal.
Feb 16, 2011 | Pioneer 1000 Watt 5.1 Surround Sound...
No sound on tv Help my mother in law is very unhappy
Check that all of the cables are plugged into the back of the TV. Check over your connections and the TV settings, I'm assuming you do have satellite or cable. Make sure that the cables you screw in are all the way screwed in and all the color coated cables are into the right color outlet, especially the red and white ones. And just to be sure, check if you accidentally hit mute.
Even if you have an S-video connection it is suggested plugging in the audio cables if all else fails.
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Nov 01, 2010 | Pioneer PureVision PDP-503HDE 50 in....
My Pioneer Elite PRO-111FD just shut off on it's own, and now won't turn back on. No green or red indicator light... nothing. Any suggestions?
Check your power source (electrical outlet) and the power cable. If electrical outlet is ok, try using a different power cable (the cable that you plug on to the electrical outlet going to your TV set). If everything is ok but still no indicator light, call your technician there might be a problem with the TV power supply.
Sep 08, 2010 | Pioneer Elite PRO-111FD 50 in. Plasma TV
Green and purple scrolling lines
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 27, 2017 | Samsung LN52A850 52 in. LCD HDTV
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
Pioneer PDP-503PU
Very possible,but yet,this might be the manufacturer defect power supply which they will fix it for you free;but before we jump to this conclusion,you need to test it first:
-Unplug the power cords.
-Unplug the media video cable from the box to the tv.
-Check all the pins on the video cable are in place as well as the connectors both behind the TV and the media box.
-Reconnect the media box and TV with the video cable(DVI+VGA in one) and have at least a video component hook up to it(ex. dvd player/VCR or comcast box) be sure this video player is turn on and running,at the same time,be sure it is under the right video input.
If you have tried the above steps but still doesn't work,call 1-800-pioneer Tuesday-Thursday at7amPST and address your issue to them.
Let me know if you have any additional questions!
solutiondoct
Oct 07, 2008 | Pioneer PureVision PDP-4340HD 43 in....
S cable to pioneers 43
there will be a hotkey to output video (ctrl+f 6 or ctrl+f4 or fn+f4) depending on the model of your laptop
also set the display properties to output video to tv or external device.
thanks get back to me if it dosent work.
Jul 20, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Proper input for TV audio signal
Do you have your DVD player running through your receiver? You want the red and white (audio) cables to go from your DVD player to your receiver and the yellow (video) cable to go from your DVD player to your TV. Separate the red, white, and yellow cable into separate strands if you need to, but be careful not to tear the insulation. They should pull apart fairly easily. If I'm totally off or you're using a coaxial or component video/audio cables or a fiber optic cable, let me know. Hope this helps
Feb 16, 2008 | Pioneer VSX-D812 Receiver
Pioneer PDP-425CMX 42 in. Plasma Television Logo
140 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
