I have a armstrong compak 10 gas pack and I replaced the circuit board and the lcd light is blinking 4 times then it stops and blinks 4 times again can you please tell me what this means.
    Guru:
  • 402 Answers
Hi, Silver Wings
Although there are a number of things that can cause this scenario (a "lockout"), it is usually related to an air flow problem (dirty filter, blower wheel, indoor coil, duct problem, dampers closed, return air or supply air registers blocked, etc.), a failing temperature limit switch, or is related to a flame sensing problem.
The flame sensor is easiest to check and they rarely fail. You can clean it with a scotchbrite pad and inspect it for cracks in the porcelain. Some of the air flow issues you can check, and others will require a trained technician. Testing the limit switches requires an electrical test meter and knowledge of how to use it.
If I were to make a guess based only on the information you have given me, I would be looking most closely at the air flow.
Thanks, Ben
Posted on Sep 02, 2010
When I plug this tv in, a red light blinks 2 times and stops, and blinks another two times and stops and keeps doing it over and over again....
THE MAIN POWER BOARD IS DEFECTIVE SOME VOLTAGES ARE MISSING SO THATS WHY SET BLINK TWO TIMES PLEASE REPLACE POWER BOARD
Apr 05, 2016 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Bought in Dubai 3 years ago Pan.Viera LCD 32"\r\nStandby light flashing red/green. Have to switch on with on/off button after a few minutes switches off itself..........then back on itself
Power LED Blinking timing chart
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
blinking
1 dg board, (stv 5v sense time out)
2 d board
3 d board
4 p board
5 d board
6 su sd sc boards
7 su sd sc boards
8 ss board
9 panel config
10 digi board-
11 pb board
12 h board
13 dg board
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Power light comes on for about 30 secs, something clicks and both power and ocp lights start blinking contineously. the screen does not light up
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
Jun 03, 2010 | Sharp LC-C4655U 46 in. LCD TV
My TV just turned off and the power light flashes 8 times. what is the flash code for 8 times on a panasonic TC-50PS14
thought I would post this here for everyone.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
May 14, 2010 | Panasonic Televison & Video
Gas heater circuit board
On the bottom door where the blower foor is located,
look on the back of it. It should have a Electrical print
and at the very bottom A Troubleshooting chart for
the control board. It is hard to find but it is on there.
Usually a solid Red means system is ready and good
to go.
Good luck, if you need anymore help let me know.
Feb 14, 2010 | Heating & Cooling
MY TV DOESN'T TURN ON....POWER LIGHT BLINKS
power supply board is dead and needs to be replaced. very common problem.
Oct 30, 2009 | Samsung LN-S4051D 40 in. LCD Television
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Plasa TV's Power light is blinking no pic no sound
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 28, 2009 | LG 32LX1D 32 in. LCD Television
Heating & Cooling Logo
480 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
