Question about Logitech Webcam
My video looks like it has frosted glass covering it how do i fix it
  • 97 Answers
It it hard to say what the issue is without seeing a picture, but from your description it sounds like there is some dirt or a fingerprint on the lens. You can take a moist Q-tip and gently clean the lens and see if it improves picture quality.
Posted on Sep 01, 2010
My sand blast box glass is frosted
The glass has been damaged from the sand and will need replaced. Many companies offer cheap replacement windows along with stick on protectors for the inside that you can change when it gets frosted. We change our stuck on protector at work about once a month find the brand and look them up online for parts
Feb 22, 2017 | Cars & Trucks
Light changing
The frosted glass cover over the lamps in your video is held in place by the knob / nut at the very bottom. Support the glass with one hand, and loosen the knob / nut with the other by tunrning in a CCW direction. There will likely be a flat washer or decorative trim between the glass and the knob (be sure not to lose these parts). The knob / nut should only be hand tight, but that doesn't stop some people from using tools to tighten them.
Once the nut has been spun off, the weight of the glass will be in your hand. Gently lower the glass. Inside, you may find a washer and felt. Depending on yur particular glass, it may have neither - but if it does, you should reassemble the washer & felt in the same order as it is designed to help prevent cracking the glass if the knob / nut is overtightened.
Relamp, repair & clean as needed and reassemble in reverse order of disassembly.
I hope this was helpful!
May 16, 2013 | Air Purifiers
What is a light box?
A lightbox is a container that has light bulbs inside and is covered by frosted glass. The light is about 5000K (bright to not strain eyes). They are generally used to look at bacteria growth, x rays, slides or photographs
Jan 10, 2013 | Crafts & Hobbies
DISSASEMBLEY OF A DOUBLE PANE GLASS WINDOW TO REMOVE WHITE FROST GLAZE BETWEEN THE PANES?
How to Replace Double Glazing in uPVC WINDOWS Cheaply replace blown double glazed window panes in uPVC windows following this video. You just need to look for a local double glazing supplier. Look in local directories for uPVC or Glass manufacturers or suppliers, or use the Internet. Some also deliver to your door. Save a fortune by doing it yourself! Go to this youtube video: https://youtu.be/hyn8BQXgquE or search on google for "comeinhandynow double glazing"
Sep 07, 2012 | Home Fencing
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Bottom of ice maker is frosted up & leads to food getting frost
Sounds like your freezer is pulling outside air into the freezer from the dispenser door or around the door seals. This could be a defrost problem beginning as this is moisture remaining inside the freezer compartment and not being taken out during defrost. So it may be a good idea to look into the back of the freezer and see if there is frost forming also on the rear wall. If yes you will need to manually defrost by unplugging the refrigerator and removing the rear panel in the back of freezer to expose the evaporator coil. If frozen over I want you to defrost with a hair dryer until we can have a look at the defrost heater below these coils. The heater in your model PSS26MRSS has glass around the heating elements and will be easy to see if the element is burned out. If burned out the defrost heater part number WR51X10055 and the defrost thermostat part number WR50X10068 should be replaced. Let me know if you are ready to begin or if this is helpful. If by chance these 2 parts look OK then we will need to look over the main control board for burn marks or signs of heat damage. I'll be here if you need me Thanks, Sea Breeze
Aug 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Coils frosting over in freezer. GE Profile PSF26NGPB BB
Replace the defrost thermostat and the defrost heater in the freezer section.
The heater is glass covered and will look dark/burned if it is bad.
Mar 17, 2009 | GE Refrigerators
My GE Eterna side by side is emitting cold air from the freezer but not the fridge. Just noticed today. Not totally warm though. Appliance is 5 years old
most likely you have a def system failure. look in teh freezer compartment at teh back wall and you'll probably see frost build up the cover. the most common culprit for ge refrigs is bad def heaters. its very easy to tell by removing the rear cover melting the frost out wiht a hair dryer. then you will see either 1 or 2 glass rods with springs in them those are your heates if 1 or both of the heaters are burnt looking then you need to repl them. good luck peyton
Jan 22, 2009 | Refrigerators
Refrig section frosting up
repairing Sub Zero under warranty Sealed System. Evaporator Change Out HD video
Jul 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Logitech Webcam Logo
22 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
