Question about Magnum 257 CB Radio
Hi my mag257 when i key the mike .the tx light up but no aduio sign on lcd .leave radio on for 5 minutes key mike again .all working .your roger
    Scholar:
  • 137 Answers
Hi sounds like bad caps in your radio.. also if your running a power mike, check the battery.
i suggest you post your problem on the radiomods forum, where there are loads of radio technicians browsing the forums.
http://www.radiomods.co.nz/forum
Posted on Sep 01, 2010
Receives,no Tx
Many possibilities:
1: The radio took a hit and broke the PCB or the connection to the RF out jack.
2: Some other PCB joint failure
3: The RF output IC is toast
4: The driver is toast
5: The tx oscillator is so far out of whack it cannot develop the frequency it is set to.
6: You have a bad cable or antenna connector
7: You have a bad battery, battery contact or power connection
8: You have a power supply or other problem
Sep 26, 2015 | Icom IC-T7H VHF/UHF Handheld Dual Band...
Why does the tx light flash on my ftdx5000?
There are several things that can cause this.
1. Powered on with the mike keyed
2. Accessories plugged in the back
3. Power interrupted
To fix this leave the power on, UNPLUG the unit and wait for it to power drain. Turn the unit off plug it back in. If that does not take care of it, take the microphone off and any accessories and try again.
Jun 15, 2014 | Yaesu FTDX5000 HF base station transceiver
Tone Sound when Keying mike
You probably are referring to a "roger beep" which can be enabled to make ordinary transmissions annoying to anyone on the receiving end. Usually it is possible to disable this "feature".
Jul 26, 2013 | Radio Communications
Baofeng Uv-5r beeps on tx
Hi Nick,
Your two way is giving you a roger beep, when you release the PTT, is that correct?
If so, your manual if you have one, and if you can decipher CHINGLISH, will tell you how to stop the ROGER BEEP.
Because these nasty little units are mass produced in China, their English translation of the user manual is harder to work with than the nasty little radios they are printed for.
Unless you have a mate who can translate Chinese to PROPER english for you, then you are in the same boat as the many other silly sausages that bought these crappy things.
They are cheap & nasty radios, like anything else made in China, that's not to say the Chinese people a bad, just the companies that produce this rubbish in great quantities for gullable folks to buy & cry.
Sorry, but I too got sucked in buying Chinese radios, Never again.
I hope you find someone to translate that Chinglish manual for you.
Sincere Best wishes,
Peter
Jan 05, 2013 | Dual Baofeng Uv-5r Band Uhf400-480mhz...
Mirage 88.. RX okay TX distorted
try the original mic . If its still distorted then it,s a radio problem.
Mar 14, 2012 | Galaxy Radios DX- 88HL Base CB Radio
I removed my Roger Beep from my Eagle Sidewinder 400, It still receives but will not transmit. What do I have to connect back up for it to start transmitting again? I'd be Thanking you for any help.....
If the radio is not going into TX, then you have not connected the TX line back up,
If there is no audio when you TX you have left the audio wire off.
The radio usually needs 4 wires.
TX (Puts radio into TX)
Audio (this carries the audio from the mic into the modulator)
Screen (ground cable (earth))
RX (not as common these days)
May 18, 2010 | Radio Communications
HOW DO I INSTALL ROGER BEEP ON A GALAXY 33 CB RADIO
Does the roger beep come with instructions? It can vary between beep boards.
Typically it gets installed inline with the mic jack.
There is a wire or pin on the board where the tx wire, and the rx wires go.These wires get disconnected from the mic jack, then a wire goes to the tx pin. Then there is an audio wire that gets connected to the audio wire of the mic jack. Then the black wire to ground, and the red wire to switched 12v right off the power switch.
Here is a schematic of the board connected to the mic jack so you know what pin is what.
Again, I would need to know what roger beep board you would like to install.
Feb 22, 2010 | Galaxy Radios DX-33HML 40-Channels Base CB...
When i key up the mike the tx/rx light and the ant
your swr setting are off wack fix your swr
Oct 02, 2009 | Cobra 29 LTD CB Radio
Superstar 3900 with no USB or LSB on receive.
most likely been fiddled with and out of alignment. If you have a freq counter and a volt meter you could possibly fix it yourself. look at cbtricks.com for the aligment procedure.
Jun 13, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Keying the mike
Hello Adam, first off, do not unhook the antenna then key the mic; you run the risk of blowing the final transistor out of the radio, then it will not TX.
The digital TX lights can be adjusted high or low by a cb tech. All they are is a general reference as to how much power is being dead keyed; usually around 4 watts.
For the best performance, the antenna needs to have the SWR set with a meter so all your signals are getting in and out. A mismatched antenna system can lose you about half of your power and range; and that's hard on the radio also.
If your radio was tuned up by a shop tech, you would see the digital go part way up, but when you talked into the mic, the digital would go almost all the way up. I hope this clarified the situation for you,,, Let me know,,, Mechanic
Oct 28, 2008 | Radio Shack TRC-503 CB Radio
Radio Communications Logo
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
