Question about Canon PIXMA MX310 All-In-One Printer
Printing wirelessly through vista?
Is it possible? I don't know how to do it.
  • 1tia1 May 16, 2008
    well I have 3 compyuers in one household and I wanted to know if I could connect the printer wirelessly to the other computers..
    I have a Canon PIXMA MX 310
Explain in more detail
Posted on May 14, 2008
How to set up wireless printing with disc
Here are the minimum details needed to answer this kind of question:
1. Operating System :
Windows XP, Windows 7, Windows 8, Windows Vista?
2. Printer make/model:
(this is important to determine the wireless properties of printer)
3. Network Connection:
(is the laptop connected to the same network as the printer)
If you are working with a new printer (see item 2) and you have a network on which you have your notebook connected, there are so many possible ways to connect the printer to the network that it's hard to say.
If you are working with an established printer that has wireless services running, you may need to know either the Network Name of the printer or the IP Address of the printer.
Your best bet is to make use of hp's extensive Wireless Printing Center (see link below).
Wireless printing center
Feb 26, 2014 | HP Pavilion dv6000z Notebook
Do I need a cord from my computor to the printer to set it up or just the disk?
While this may seem oversimplified, RTM = Read The Manual on setup.
If it's wireless, you don't need a cable to setup the printer with the computer's OS.
If it isn't wireless, then yes, you will need a printer cable to set the printer up with the computer OS.
Oct 21, 2012 | Canon MP560 All-In-One InkJet Printer
Hp pavilion dv8000 wireless printer does not work
Do you have more than one instance of the printer installed. If that happens the computer gets confused and don't know which one to print to. Also only one can be active if you have two instances of the same printer and you could be printing to the inactive one. Click Start/Control Panel and check your printers to insure that there is not more than one instance of the same printer installed.
Also check down at the bottom right near the time and if you see the printer icon open it and clear out the queue. If you've printed to an inactive printer the queue will block you so just delete or cancel the items in the queue.
Also check your printer properties to make sure it is printing to a TCPIP wireless connection and not a usb connection.
May 01, 2012 | HP Pavilion dv8000t Notebook
NOT COMPATIBLE WITH VISTA?
WPS54G should work with the VISTA also.
But the disc will not run on the VISTA.
What you can do , you can set up the printer manually.
Once you are able to set up the print server with the router.
You will need to add printer port on the computer.
Click Here to know step by step solution.
Oct 25, 2009 | Linksys Wireless-G WPS54G Print Server
Print from vista to xp with usb connected lexmark 2350 results in access denied error after timeout. Vista access shared printer through a wireless router. Any recommendations?
Okay, I need to understand your topology a little better. You have two PCs, one using Vista and one using XP. Both PCs are connected to the Wireless modem. The printer is connected to the XP PC and shared across the local network? When the Vista unit sends a job to the printer, you get an access error message. Is this description accurate? Normally this would be caused by the sharing settings on the XP unit. Please make sure you have the sharing options correctly set on the XP unit and then get back to me if I've given you an incorrect path to follow. Don
Jun 06, 2009 | Lexmark X2500 All-In-One Printer
My wGPS606 wont print on my Windows Vista laptop!
I just found a way to enable the HP P1006 with a different print server (Liveprint on Orange Livebox router). Perhaps this might work with the WGPS606 wireless print server?
I set up the P1006 via the print server as instructed (I'm using Vista 32 Home Premium) but no test page would print.
BUT!! (with thanks to another another forum):
I selected printers, then right-clicked on the wireless printer I'd just installed and selected 'properties'.
Under the 'Ports' tab I deselected 'Enable bidirectional support'.
Problem solved.
Hope this helps.
let me inform you that this printer is not compatible with any wireless print server. The drawback is that it is not possible to network such printers. A printer needs a steady flow of data, which is easily accomplished when it is connected directly to a PC, but cannot be guaranteed when the printer is connected via a LAN. Also, these technologies require intensive handshaking between the driver and the printer.
The host-based software uses the computer's resources to process print commands and rasterizing data, taking advantage of the computer's memory and processing power."
Sorry I can't be more upbeat - but its probably useful to know that someone at HP thinks the job's imposible - unless someone out there has a fix?
May 11, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Wireless Printing problems Vista to 10.3.9 Mac to Brother Printer
I have a wireless Mac ,version osX.4.11. I have a Colorsmart HP Priner 4100. I have created documents in IWorks Pages. I can not print directly. I have to save the doc as a PDF email, email to myself, go to Safari, then the printer will print. What am I doing wrong?????
Feb 26, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I just bought a 4720. Iy has windows vista. I also have an old Toshiba sattelite with windows xp. To connect to the internet the toshiba works every time. The new acer sometimes does but mostly does not....
You will have several problems to install Windows XP in a computer designed to use Vista. I personally don´t think it´s fair.
But your problem possibly is not related with the OS. Are you using a wireless router? If yes, the problem may be your 4720´s wireless adapter (probably internal). You can test it by using another wireless network (most malls, shopping centers, airport or hotels have avaiable public wireless internet access).
Apr 19, 2008 | Computers & Internet
Lexmark 4580 wont print even though when installed it prints a test page. do you know of any common problems? running on windows vista
i just set up this printer two days ago - got the wireless indicator to finally go from orange to green (not sure how, it always said it was connected to my network and everything looked good when i had it print a wireless setup page)...
i've got it on a mac OSX and windows vista (the main reason i wanted wireless printing! two laptops in the household) - both are spotty on when the computer will connect and print - more often not than so.
it's driving me crazy, as i haven't had too much time to figure it out myself...
Apr 07, 2008 | Office Equipment & Supplies
Canon PIXMA MX310 All-In-One Printer Logo
79 people viewed this question
old marine
old marine
