Question about Altec Lansing 220 Computer Speakers
The power button lost it's spring/tension & therefore can no longer turn on spkrs at all. Power button fell inside spkr grill. Is it possbile to disassemble & retrieve button & attempt to reattach it?
  • 3,083 Answers
It's always possible to open up a speaker, and unless it's glued together, you might be able to without damaging it. Usually when buttons break, there is plastic damage, and it's "iffy" if it can be fixed. You can often find a reasonable replacement, but not always, due to different types and designs, fasterners, etc. Most speakers are screwed together, so it's entirely possible to find the parts of your switch.
Good luck, thanks for using FixYa, and hope this helps.
Posted on Sep 02, 2010
  • Alex Raziel Dec 01, 2010
    sry but omg.......same thing happen to me the power button fell inside i tried to open the speakers but no chance there are 4 useless screws (sry if im wrong dunno english to well) and rest i just cant open it........... only if i force it alot and eventualy it will break....something but dont wanna do that so ........
How do u hook up a set of 4"x 6" HD Scosche speakers in a 1993 GMC Suburban
i`ve got the the same truck,,pry up the corners of the dash grilles,carefully so not to crack them,usually the clips tend to break off,so grab some epoxy from hardware store first(gonna need it).Remove 4 7mm bolts and pull spkr out,,cut wires and strip,,,left side will have gray and tan,gray is positive,,right side will have light green and dark green,light green is positive(GM wiring is lights in the front,darks in the rear).Using connecters attach new spkr pigtails connect spkrs and re-install into dash. Using epoxy replace clips on grilles waiting for epoxy to set,,carefully replace grilles and your done. GOOD LUCK
Jan 24, 2013 | Car Audio & Video
I got a teac ag-v8060 audio/video surround receiver and I'm tryin to hook up some surrounsound speakers along with a jbl g cinema sub can you describe where the wires go in the back of receiver? The sub...
On the back of the receiver, there could be "pre out-subwoofer". If your subwoofer has the same type cable input, that would indicate it is a powered(amplified) sub. Connect those two. If subwoofer only has red/black speaker inputs, it is a passive sub, which means spkr signal runs thru it and then to your main left and right spkrs.. Run your receiver main or front spkr left (red/black) and right (red/black) to those corresponding sub inputs, and then sub spkr outputs to each of your main left/right spkrs..
For surround, on the back of the receiver, there should be spkr outputs (red/black) noted as "rear".
Just make sure red to red, and black to black.
Hope this is helpful.
Apr 28, 2010 | Teac AG-V8060 Receiver
How to run wires is series fof 3 subs
If they are single voice coil speakers (1 positive and 1 negative terminal on each speaker) then connect from amps' Positive output terminal to spkr. 1 positive terminal, THEN spkr. 1 neg. terminal to spkr. 2 positive terminal, THEN spkr. 2 negative terminal to spkr. 3 positive terminal, THEN spkr. 3 negative terminal to amps' negative output terminal.
That is 3 speakers wired in series. if each spkr is 2ohms, then you will have a total 6 ohm load. If 4 ohm spkrs., then a total 12 ohm load, if 8 ohm spkr., then a total 24 ohm load.
Be careful because amps do not like these odd ohm load totals. You might get away with a 6 ohm total load. Depends on the amp.
Mar 27, 2010 | Jl Audio 10W6v2 Car Subwoofer
Speaker Problems
push the "sound edit" button on the remote, it will bring up things like, bass, center spkr, rear spkrs.. change the volume control on the rear spkrs.
Apr 09, 2009 | Samsung YP-U3 MP3 Player
I have 2 10inch spekers in a box that just stopped playing the bass! can anyone help? ive checked the fuzes!
If the fuses are good , this could still be a prob with amp, check spkrs with a ohmeter(cheap one from the Shack or anyplace) by touching both leads to spkr terminals, disconnect spkrs first.Have ohmeter set to ohms Rx1 and you Test amp out put by connecting two spkrs that you know are good. Good luck and please rate this answer,thanks.
Apr 06, 2009 | Mac-Audio Compact 220 Car Subwoofer
Speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Jan 27, 2009 | Denon AVR-2105 Receiver
Onkyo TX -601 Zone two stopped working
any luck with sorting out the amp?
Feb 24, 2008 | Onkyo TX-SR601 Receiver
Zone two spkrs will not play
How many sorround speaker connected to the subwoofer?
Feb 23, 2008 | Onkyo TX-SR601 Receiver
Zone 2
if you have a main speaker system working properly, takea known good amp to ch2. wire the main pre amp out to amp 2 input.. turn both units on(no spkrs connected), fire it up. if the amp does not go into protect mode, turn ALL power off to the system.,connect one Spkr channel on A2, AND TURN THE VOLUME DOWN FIRS!!!!. pOWER UP THE SYSTEM AND SEE WHAT YOU GET.BE GENTLE WITH VOLUME SETTINGD! If ch 1 works, repeat procedure with ch 2 pre amp out.
Nov 11, 2007 | Onkyo TX-NR801 Receiver
Altec Lansing 220 Computer Speakers Logo
145 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
