Question about Canon BubbleJet i560 InkJet Printer
The printer does not respond to anything, I have checked the power, no respond. it is like there is no electric on the line, have plugged other things into outlet, it works. .
  • 2,973 Answers
The wall socket is working fine and the printer is not. SO the link, ie, the power cord may be defective. Or the power socket on the printer or the power on switch. Any of these could be the culprit. The power socket on the printer is unlikely but the plug there could. If you have a spare power cable or your friend has, just borrow it for a few minutes and try it out. If it does not work then the power on switch is the culprit. And to change the switch you need professional help. Biggest problem being that unless there is power reaching the printer, nothing can be said firmly if rest of the printer is fine or not.
Posted on Sep 02, 2010
HP 309a will not respond to anything, will not power off
Go to control panel, click on devices and/or printers, right click on the printer, click on troubleshoot
Apr 05, 2012 | HP Photosmart Premium C309A All-In-One...
All lights on wont shut down wont respond
Hello, maybe you have to do what i call hard reset, unplug it from the light then look round if you can locate any fuise on the print take it off, then allow it for 1hour and try again later
May 07, 2011 | HP Deskjet F2210 InkJet Printer
Lexmark X2350 All-in-one does not respond to anything. When i plug it into an outlet the power button lights up and stays lit for 10 seconds then blinks once and stays lit for another 10 seconds and blinks...
Your problem lays in to one of the output capcitors in the circuit board. To have it repaired would cost more than purchasing a replacement printer these days.
I would just purchase a new one instead
Jan 28, 2011 | Lexmark X2350 All-In-One InkJet Printer
Power button not working on Lexmark X2530 multifunction printer
OK, if you can work a volt meter it will help. We want to double check the output of your power supply (P/S) based on the specs written on it , or in the manual. If the P/S is known good, when the printer is turned on, do you hear anything? listen for the faintest fan. If you hear a fan, printer is getting power. if you hear nothing and see nothing, check for a fuse by the P/S plug in somewhere. If you don't see one outside, there is one on a board that needs replaced inside the printer. Check the fuses for continuity. Ill bet its as simple as a bad P/S, lexmark is cheap plastic ****, but still lasts longer than THAT!
Oct 13, 2009 | Lexmark X8350 All-In-One InkJet Printer
Sears Craftsman Gar. door opener won't respond
There isn't a fuse. You are going to need to remove the cover on the opener and find out where you are losing the power. Maybe a neighbor has a volt meter you could use. I would check the power cord and then the logic board. Makes no sense but I would check for burnt or missing traces on the printed circuit board especially around that small transformer.
Aug 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
All the lights are blinking
Un plug it from power and signal
Just plug the power back in and see it id asks to do anything
Jun 19, 2009 | HP DeskJet 5740 InkJet Photo Printer
Canon pixma IP2000 not starting
dear,
uninstall the software of your printer and reinstall it...hope it may work.
thanks.
Jun 16, 2009 | Canon PIXMA iP2000 InkJet Printer
Starting problem
Pls. check your printer power cable that may be faulty
Sep 30, 2008 | HP PSC 1210 All-In-One InkJet Printer
Problem with k80 hp printer
ok..turn it off...and then press the power button, remove the power cord..wait 30 seconds..plug it back in..try that..
Jul 10, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Canon i560s printer
Test w/ multi tester the continuity of printer cord from plug to male female plug two ;line shake the wire if not stable the contuinity power cord open./ check also fuse .
Nov 12, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Canon BubbleJet i560 InkJet Printer Logo
87 people viewed this question
old marine
old marine
