Question about RIM BlackBerry? Curve 8330 Cellular Phone
Hi! My Blackberry Curve has loads of problems only just started. 1) Does not ring out! 2)Alarm clock does not ring! 3)When connected to Bluetooth "Nokia" Car Kit my Car Radio cuts out! 4)Will not play Video/s (says voice activation is activated). 5)Unable to get into Voice Calls mode to check details re; 4). Help! Regards, Jan
  • 677 Answers
Hi, we will have to check one by one what exactly caused all to malfunction.
First reset the phone might be caused by Virus.
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Hope this Tip helps.contact me if that does not work.
Have a nice day.
Posted on Sep 01, 2010
How to pair up nokia bluetooth headset BH-213 with blackberry curve 8520 ?
Hi
1.Ensure that your phone is on and the headset is off. 2. Press and hold the multifunction key (for about 5 seconds) until the green indicator light starts to flash quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. When the headset is connected to your phone and is ready for use, the green indicator light flashes slowly.
thank You
Aug 31, 2010 | Nokia Bluetooth-Headset BH-213 2600...
Tip
Rip / download DVDs to Blackberry Storm/Bold/Curve (Blackberry 6.0) for Watching
Quoted from: http://www.daniusoft.com/convertdvd/dvd-to-blackberry-storm.html
Blackberry Storm/Bold/Curve, the recent"Berrys" bring BlackBerry's first serious stab at the consumer market.Your email is going to be totally awesome with those three Blackberrys.Other than that, you could also enjoy videos and DVD movies onBlackberry Storm/Bold/Curve with its excellent playback quality.
Media player (video part):
Storm: MPEG4 H.263, MPEG4 Part 2 Simple Profile, H.264, WMV video (plus 3.5mm output)
Bold: DivX 4, DivX 5/6 partially supported, XviD partially supported, H.263, H.264, WMV3 video (plus 3.5mm output)
Curve: MPEG-4 and H.263 video
SinceDVD is protected by Digital Copy, you will need to crack thatprotection first and then convert DVD movies to Blackberry compatiblevideo formats.
Lucky enough, we have Daniusoft DVD Ripper,which is the best DVD ripper to rip DVD to Blackberry Storm/Bold/Curvecompatible formats, such as DVD to MPEG-4, DVD to WMV, DVD to H.264,whatever you like.
You don't to have toget through a million hoops to rip DVDs with this DVD to BlackberryStorm Converter, it is just as easy as 1, 2, 3.
Step 1:
Load DVD files, you will find all DVD titles be listed within 1 minute.
Step 2:
Edit the DVD videos if you would like to make some recreation.
Crop – Set the video zoom to 16:9/4:3/full screen.
Effect – Make special effect through brightness, contrast, saturation, built-in effects.
Watermark – Add text or pictures on the video.
Step 3:
Click Profile to choose MPEG-4, WMV, H.264 as the output format for DVD to Blackberry Storm/Bold/Curve.
You are also allowed to customize frame rate, bit rate, resolution, encoder, etc in the settings.
Step 4:
Hit "Start" to rip DVD movie to Blackberry Storm/Bold/Curve.
Asfor how to put DVDs to Blackberry Storm/Blod/Curve, after you get thefinal converted DVD files which are compatible with Blackberry storm,connect your Blackberry, set it to be in "Mass Storage" mode (UMS), anddrag'n'drop the file in your Videos folder on your blackberry (youdon't need the Desktop Manager to do that).
on May 06, 2010 | Cell Phones
How do i connect bluetooth
Please try this simple steps
1. From the BlackBerry smartphone home screen, select the Options icon.
2. Select Bluetooth.
3. Highlight the Bluetooth and press the Menu key enable it.
4. Select ADD devices option and then connect..
I hope this information is helps
Nov 10, 2009 | RIM BlackBerry Curve 8310 Smartphone
My blackberry curve 8330 is stuck on white screen saying JVM 513. How do I fix this?
To Fix this issue you need to re-install Blackberry Device Software
Befrore performing these steps take a backup of your Device Data.
1.Connect Blackberry device to your Computer and open Blackberry Desktop Manager.
2. Double Click on Application Loader
3.Click Next to start the installation process.
4.Type your Blackberry smartphone password,if prompted and Click Ok.
5.Select the check boxes next to the names of the applications to be loaded,and then click Next.
6.Click Ok> NEXT>FINISH
Nov 08, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Cant get my bluetooth to pair or it says it is connected cannot transfer anything across
In this case you have to fallow few troubleshooting steps please fallow this.
1. From the BlackBerry smartphone home screen, select the Options icon. 2. Select Bluetooth. 3. Highlight the Bluetooth paired device in the list that is experiencing this issue and press the Menu key. 4. Select Device Properties. 5. Set Trusted to Yes.
Oct 29, 2009 | RIM BlackBerry Curve 8310 Smartphone
No sound from Bluetooth
sound as in you can not hear the person speaker or the phone ringing on your end....if these are the problems maybe the BT headset is faulty
Mar 04, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
BlackBerry won't pair with device anymore via Bluetooth
1. Go to Options/Bluetooth
2. Select device found
3. Select device properties
4. At Trusted select yes
It'll never ask again
Dec 30, 2008 | RIM BlackBerry Curve 8310 Smartphone
Samsung Bluetooth WEP210 and Blackberry
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the Blackberry
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Dec 15, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
RIM BlackBerry? Curve 8330 Cellular Phone Logo
160 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
