Question about Philips 42PFP5332D 42 in. Plasma Television
42pfp5332d plasma led rosso lampeggia 2 Volte
Why is my D5160 printer flashing red Exclamation sign?
sto cercando di stampare documenti ma non parte. ho sostituito la cartuccia di nero, ma il punto esclamativo rosso, lampeggia sempre. la sprngo manualmente,ma dopo si riacende da sola.che cosa ha?grazie
Feb 16, 2011 | HP Photosmart D5160 InkJet Printer
I have had my TV-- a 42" Philips plasma-- for
it can be a poor contact or puffed capacitor in the power supply board
Dec 06, 2010 | Philips 42PFP5332D 42 in. Plasma...
My philips 42pfp5332d/37 when i turn it on the blue light comes on and it has no picture and just makes a clicking noise. If you look at the back you can see 2 green lights go on and off. it happened after...
Power supply board is dead.Replaced the power supply board,that the board where the power a/c cord go into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 06, 2010 | Philips 42PFP5332D 42 in. Plasma...
Orange light blinks and tv wont turn on
First, check the wires properly, adjust them or try at another power point.
Rerview your User Guide for settings properly.
If this does not solve the problem, I suggest to contact this definitively establishing technical service, including technical service Phllips recommended when warnings occur leds.
Hope helped.
Nov 26, 2009 | Philips 42PFP5332D 42 in. Plasma...
Power Problem
usually blink code on front gives direction but first thing to do would be to determine if surrounding sustain boards are causing draw on power supply by disconnecting them one at a time from power supply. y is on left looking from back and x is on right looking from back. if led goes solid with either board disconnected check supply voltages and if come up and stay up replace that board. if no change then you would need to verify vs on command coming from logic main to power supply. should be labeled on power supply connector and should be 3 volts. if present replace power supply if not present verify if logic main board sitting underneath signal board has one solid and one blinking led on if verifying normal operation and if so replace small signal board
Aug 15, 2008 | Philips 42PFP5332D 42 in. Plasma...
Ni picture no sound
Do you get the blue Led in the bottom left of TV. If yes send me a comment with the first 8 digits of the serial number. There is a issue with certain models within a certain date range. That can be upgraded with a firmware upgrade.
Jan 09, 2008 | Philips 42PFP5332D 42 in. Plasma...
Philips 42PFP5332D 42 in. Plasma Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
