Question about Samsung Cell Phones
My bluetooth is connected to my captivate but I can't get it to connect. it worked when I first paired it to the phone but it it's not working anymore!
Delete the first info on the phone and also on your captivate and try again,hope this works for you
Posted on Sep 01, 2010
How to pair my sprint slx-800 to my android phone
You should search for this topic and answers, First.
Try 0000 that's the default for all bluetooth accessories.
If that doesn't work, here is generic instructions:
Paring a Bluetooth Handset with Android phone:
Instructions:
Now that you have your headset in pairing mode, proceed to pair it with your phone:
From the home screen, press the Menu key and then select Settings.
Tap the "Bluetooth" toggle to ON.
Tap Bluetooth to scan for devices.
NOTE: You will automatically be connected to an available saved device when Bluetooth is turned on.
Tap one to connect.
NOTE: A security code may be required. (Try 0000)
The Bluetooth connected icon will be displayed in the notification bar, and the device will now be labeled as Connected.
Place calls using the Bluetooth headset
Ensure the Bluetooth headset is paired with the handset.
Place the Bluetooth headset over your ear.
Dial the desired the phone number on your phone, and then tap Call.
Receive calls using the Bluetooth headset
Press the Call button on the Bluetooth headset when a call is received.
Aug 20, 2015 | Sprint Cell Phones
Bluetooth pairs but will not connect
Try pairing and connecting with another headset. Or delete the pairing and pair again.
Mark
Motorola Support
Aug 21, 2014 | Motorola Mobility Hx550 Bluetooth Headset...
My cell phone's bluetooth not work proparly
Maybe the problem with your connection of your bluetooth is in the pairing of the devices of the other phone that you are connecting.Try to erase some other paring devices on your phone.You can find that in the settings of the connection on your phone.After you erase some of the pairing devices on your phone kindly try to connect via bluetooth.
Jul 17, 2011 | Home
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
Troy Windconnect printserver has stopped working
Due to tolerances in manufacturing, some Bluetooth-adapters/receivers do not stick to the Bluetooth-standards exactly. If this only applies for one adapter/receiver in a pair everything works fine nevertheless. But if both do not stick to the standard, they might not be able to work together, although both would work with a standard-conform third one.
Before your mainboard was replaced, only your printserver was not exactly standard-conform. Now with a new mainboard (and therfore a new Bluetooth-adapter on it) just by accident your Bluetooth-adapter does not confirm to the standard, too.
If all this is right in your case, the solution would be to buy a Bluetooth-usb-dongle for your notebook and use this instead of the built-in Bluetooth-adapter of your notebook. If this new Bluetooth-usb-dongle confirms to the Bluetooth-standards better than your built-in adapter, this might cure the problem. Since such a Bluetooth-usb-dongle only costs about 10 Dollars, it might be worth a try.
Greetings, Michael
Feb 23, 2009 | Troy WindConnect With WindPort PC Card...
Motorola h710 bluetooth will connect to phone but no audio
I disabled the bluetooth from my phone. I then turned off my phone and rebooted it. Once the phone was turned back on, I paired it up with the bluetooth and then it worked. So disabling and removing everything and starting over worked.
Feb 03, 2009 | Motorola Mobility H710 Bluetooth Headset
Multipoint bluetooth wont work with iphone 3g
I actually have both products, and I was able to get my bluetooth to work with 2 phones. All you have to do is first pair your phone with the H721. Then in the phones functions, turn off the bluetooth so it is no longer in discovery or connected...but do not turn off the bluetooth itself, just in the phones settings. Then go to the bluetooth settings in the iphone. you should see the H721 in discovery but not connected. Before connecting it you must put the H721 into discovery mode as well. Hold all three buttons down for 19 sec. it will go solid blue. then push connect on your iphone. onces connected, go to the original phone and turn the setting back on for bluetooth connection. both are now connected. Only one may apear to be connected, but both are. test it with another phone. call each number and you will see that you can now answer both calls with one device. If the iphone is connected and phone 1 rings...the H721 disconnects temporarily from the iphone and connects to the other device to answer it. Hope this helps. Cause thats how I got mine to work.
Oct 27, 2008 | Cell Phones
Bluetooth passcode
When pairing two phones, you need to set up the connection on both phones. One will ask you to enter the password when you are creating the new connection, which you will then need to enter on the second phone to complete the connection. This ensures that only people you allow to connect (people you gave the code to) can connect to your device.
As for pairing your headset, try this link:
http://www.phonedog.com/cell-phone-research/blog/how-do-i-pair-my-bluetooth-headset-to-my-phone.aspx
Jun 11, 2008 | LG VX9400 Cellular Phone
Bluetooth wont work
Goto:
spanner - wheel click!
bluetooth -wheel click!
bluetooth disabled - wheel click!
Enable bluetooth -wheel click!
Paired devices
*EMPTY*
- wheel click!
Add device - wheel click!
after the search select the device you wish to connect to...& contiue to follow the on screen prompts & pairing instructions.
Dec 18, 2007 | RIM BlackBerry 7290
Krzr k1m won't connect to bluetooth device
Turn off the phone. Remove the micro-sd card. Restart phone. It should connect now.
Nov 22, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Cell Phones Logo
54 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
