Question about Frigidaire Washing Machines
When I set the cycle and pull the button out, the washer does not start. Is there something I can do or check without calling a technician?
    President:
  • 3,773 Answers
Please check the lid switch. That is usually the problem I always find on my ser calls.
Be sure and check the plunger on the lid to see if it might have been broken off.
Put a screwdriver in the hole and see if you hear a click.
You can also tape the two wires together at the lid switch and it
will work
Good Luck!
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 01, 2010
My lg tromm washer on the wash cycle is not spinning, and is making a grinding noise
check for something in the bowel. pins ,buttons coins etc have a technician check the spin operation.
Mar 03, 2015 | LG 4925ER1015B 4924ER1010 Used Frontload...
Why would my Amana washer not do anything but fill up with water. Nothing will function at all on all the cycles but the fill. It doesn't even click on the timer when you try to set to any setting exc
Hi Kirby
First... Caution
Because your dealing with water & electricity it can be lethal to fiddle around inside. That said...
Washing machines are controlled by a master timer unit, usually mechanical, but rotated by an AC Clock motor. If the timer is not getting voltages to the various Switches around the "timer unit" or "clock motor" then the individual selected functions won't work.
Manually Rotating to a particular function then Activating the On/Off Push/Pull switch should start things happening even if timer motor is dead. So
If your OK with AC electrical goods then open it up.
Connection wires may have fallen off or something simple. A multimeter is your best friend here. Look for the big rotary clock behind the main control dial. Listen for the clock motor running. The main Push in & out Button is the On / Off switch. Check that its got AC on the input wire & switches across to the other wire when the knob is pushed in / out. This may be the problem...
You can always call an appliance repair technician!
Good Luck
Nov 19, 2014 | Amana 3.2 cu. ft. Top-Load Washer
My the front load washer model gcvh6900jww has the red lock on the display. I accidentally held the start button for a few seconds and it locked. I tried holding the start button again for up to 20 seconds...
  1. Found This HelpfulSometimes something will go wrong in your washing machine that will cause it to lock up or stall. An overloaded washer or a brief power surge can cause this. The washer may not drain or spin properly, or it may stop the cycle in the middle of the wash. Another cause may be that the washer was stopped before the cycle was able to complete. In this case, the washer will spin and drain over the next 24 hours, but it will stall before reaching the final spin. GE has two simple methods to reset the controls
For Newer Washers:
    • 1 Unplug the washer.
    • 2 Twist the control dial around the cycle settings.
    • 3 Place the dial on any setting other than the final spin.
    • 4 Ensure that the water line is securely attached to the washer.
    • 5 Plug the washer back into the wall (making sure it has gone at least 30 seconds without power).
Nov 11, 2014 | Washing Machines
Pulled tear drop locking mechanism down but keeps springing back NFW7200TW
it looks like you have a bad door switch and is the easiest and cheapest thing to fix on the washer part number 8182634 and it's around 65 dollars.open the door unplug the washer,remove the spring and pull off the rubber boot enough to get at the door switch,remove the screws pull out the switch and unplug it,put it back together,put some soap on the spring so it will go back on easier.hope this helps,also in the washer there's a tech sheet with all the codes and tells you how to run in diagnostics
Apr 07, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
My blanco bfdw6x dishwasher has the folowing symptoms - power on, 30 min wash cycle set, after pressing start cycle button the machine sound likes it tries to start, but then cuts out and the digital...
Ours does the exact same thing. We pull it out and tip it which drains some water on the floor and then it works. It is something a technician told us ages ago, something to do with a water level switch underneath.....but its driving us mad. We have to do it on a regular basis. Does anyone know how this can be fixed more permanently. thanks.
Sep 03, 2010 | Dishwashers
Machine stopping mid-cycle
f your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
Mar 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Loader GHW9150 PW
Yes, I fixed it after 10 hours of attempting. I called Whirlpool who in turn told me to call a Tech out to the house. I talked with a Whirlpool Rep who was at our local Lowe's, she in turn called their Whirlpool Guru who told her, there is NO override or manual way to fix the lock up unit/problem other than calling a Technician.
Well, I beg to differ. I took the panel off a 2nd time, looked for a pull, which there wasn't one, so I keeped feeling around the lock from the inside of the washer. I looked for anything that would move, press together, pull down and walla, bingo, I found a piece of metal that I pulled on and it released the door!!!!!!! Yahoo, then while the door was opened, I plugged the unit into the AC, it recognized that the door was unclocked, then I turned it to spin and rinse after it started flashing the F 11 code. I knew from this site, that it meant my soap had leaked into the unit. After running the rinse cycle, I am so proud to report that the machine is back up and running!!!!!
I thought, how awful not to have an external manual release, what if a kid got locked in the unit. Yes, a kid. My brother and I use to tumble in the dryer...lol Kids do, do dumb things. So even if Whirlpool tells you it can't be done,without a technician YOU can do it!!!! I'm a 60 year old woman and proud of it....Thanx FixYa
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My Maytag Washer
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
14 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
