Question about Kenmore Dryers
I have a kenmore electric clothes dryer that does not heat up.It turns on just no heat
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 01, 2010
  • 213 Answers
SOURCE: Kenmore 70 Series Electric Dryer Won't Dry.
the vent where the air from the dryer leaves the house is blocked. if the air cant get out at the proper rate of speed the clothes cant dry properly. the vent needs to be cleaned out. not just the part be hind the dryer but all the way to the outside. if you need someone to do this for you, most chimney sweeps will handle this problem
Posted on Nov 26, 2007
SOURCE: kenmore heavy duty clothes dryer will not heat
most problems with dryers not heating is the thermo fuse is blown. bout 20 buck to replace it looks like a small white flat football. but most likely if it went out that means the the high temp thermostat is messed up too
Posted on Feb 07, 2008
rdial54
  • 14 Answers
SOURCE: Kenmore dryer (electric )
replace heat relay
Posted on Sep 07, 2008
futureloginn
  • 734 Answers
SOURCE: kenmore cloths dryer will not heat up
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Dec 02, 2008
  • 686 Answers
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Posted on Apr 06, 2009
Kenmore model 90 dryer electric will dry the clothes takes a long time. Leaves the floor surrounding the dryer damp actually wet just not puddled
Are the clothes wet AND hot? If so - check the exhaust / vent hose for kinks or obstructions. That includes the cap / flap on the outside of the house.
If the clothes are wet AND cold, then the electric heating element isn't heating likely due to a broken or poor electrical connection, burned out heating element, defective thermostat, etc..
Jul 14, 2015 | Kenmore Dryers
Kenmore gas dryer will not heat when i place clothe. runs fine without clothes
heatman101
Aug 28, 2010 | Kenmore 74672 Gas Dryer
Kenmore propane clothes dryer not heating
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
Feb 20, 2009 | Kenmore 62602 Electric Dryer
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
