Question about Canon PIXMA MP160 All-In-One InkJet Printer
Feed paper still not work
I've tried to feed magazine cover as Fixya's advice. But If I tried again with blank A4 paper, the printer still not work. The paper can enter the printer just a little part and then the printer is error. No things that can type from the printer. When paper is feeding, the sound so loud. If it true as shapirit's says, how to replace the rubber that grabs the paper?And what should I give to the drying rubber?
Hopely, I need you help and advice. Thank you
  • xxmegan Jun 29, 2008
    i put paper into it, and it always goes in at an angle..then you hear the ink go back and forth and it won't pull the rest of the paper in. i need help. =[
  • 71 Answers
Hello Dear,
There must be something obstructing the Auto Sheet Feed Assembly, you need to clean the paper path, use a vacuum cleaner or look deep into it if you can find something there, if the problem persists you should take your printer to the service center and get it serviced and surely your problem will be resolved.
Warm Regards,
Manoj Joseph
+91 9352008418
Posted on Jun 17, 2008
When faxing or scanning the paper stops feeding
Thank you for contacting Fixya Support.
Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........
Good Luck......
May 06, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Printing
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
553
Dec 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
E3 on LED paperwill not feed
What you want to do is remove all paper, the prepare to run a print test page or print a blank sheet from some program, any program. Just be ready to do this.
Now, find a magazine cover or index card stock, something firm. Cut this magazine cover to the same width as regular paper 8 1/2 in the US or A4 in Eurpoe.
Now, when you start the print job, push the magazine cover or index stock through while its printing. Apply pressure it the key, to getting the thicker paper through.
This will clear the sensors in the printer and remove the error message.
Why did this happen? In the printer, there are numerous sensors to identify jammed paper. This can happen for the strangest reasons. By pushing thicker paper through while feeding paper by running a print job, the thicker paper forces the sensors back to their original position.
Regards,
Worldvet
Nov 04, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper feed problem
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
someone replied to my problem, i tried it and its fixed 1st time, for others its taken a few attempts and then worked..
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now. hope this helps, let me know how you get on. Garty
May 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper feed and printing problem
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others, it seems to reset the sensors or something.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through!! and hey presto it worked for me, everything printing fine now.
hope it works, let me know, Garty
Apr 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer paper feed error #3
Dear EATRUNNER,
This Error is related to PaperJAM now you can find the complete solution to related this Error ,on this URL:
http://support-au.canon.com.au/contents/AU/EN/8000647001.html
i'm 100% sure ,your problem is solved ,whenever you read this page properly.
Cheerup and Be Happy Always
Mar 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam
Don't know if it's the same problem i had but its maybe worth a try. Mine is a Canon MP160 but again its maybe worth a try.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Feb 28, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Paper feed issues
Yeah i tried the cardboard as well...it didnt work first time. but as i had no other choice, i did it 2-3 more times and eventually i heard a lot of noise and to my surprise my mailbox key popped out covered in ink...
so the cardboard seems to be the magical solution. not only does the printer work again but i also found my key!
Dec 29, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Paper will not feed properly/one side of paper not feeding in straight
hi,
542
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Error number 3
Nov 09, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
42 people viewed this question
old marine
old marine
