Question about Garden
I have a 12 hp 4 stoke electic start riding mower. I need to know what the name of the part that sit directly behind the fly wheel. when the fly wheel turns it should have a connection to this part. I also need to know what the gab should be.
  • 284 Answers
Ignition coil or module
Gap is .012
Posted on Sep 02, 2010
How to install a magneto part#610759 on a 12 hp Tecumseh engine #143.622022
loosen the nut on the crank use a peace of (BRASS) put it on
the end and hit it the fly wheel will come off and most mags
just bolt on the fly wheel has a key way line it up and push
the fly wheel back on and tighten the nut done deal
Sep 16, 2014 | Garden
Mower won't start
Battery charged?,sitting on the seat?, starter or solinoid working? Take out the spark plugs and try turning the engine underneath by using the pulley. Is the oil fresh?
Apr 20, 2014 | Craftsman Garden
Mtd removing rear wheels from axel
Be very carefull, if you pull the wheels hard enough the half shaft will pop the circlip on the inside of the gearbox and come away with the wheel, this will then require a gearbox strip down, leave it soaking in penetrating oil and try again.
Jul 11, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
12 hp briggs and stratton starter
the battery may be to weak try jumping it with your car its the same voltage the starter needs to spin out fast to in gauge
Mar 29, 2012 | Husqvarna Garden
I have a 6 hp self propelled Craftsman mower with
Ok this may be a simple fix. it has a high chance that the fly wheel key has sheared, this will cuse the timing to advance and bite your hand with the rope.
remove the pull starter and the cup ontop of the fly wheel, if you look straight down at the fly wheel nut you can see a cut out in the crank and fly wheel they should be aligned up if not it has sheared. use a lever under the fly wheel and put some pressure on to to lever it up then hit the fly wheel oposite side of the lever AWAY from the the magnet. and the fly wheel should pop up. replace the key and of you go..Make sure you use the OEM brigbs and strat key it is made out of alloy. The cause of this is the blade hitting a kerb or somthing hard,
Jul 02, 2010 | Garden
Snapper rear engine riding mower won't turn over.
First take off the engine shroud and clean the magnets on the fly wheel. Also the two little prongs that are really close to the fly wheel. I use fine sand paper or emery cloth.
Second take the sediment bowl off of the carb and use carb and choke cleaner to clean out any varnish that has formed. If the bolt that holds the bowl on has a little weep hole clean it also. You can spray entire carb and any little ports in it and use an old tooth brush to give it a good cleaning. Reinstall the bowl and then try starting it.
Good luck and let me know if this helps.
thanks roundo4
Sep 02, 2009 | Garden
I have a walk behind mower with a 14 hp kawasaki engine. no fire at the spark plug
Try cleaning the magnets on the fly wheel. Use emery cloth or fine sandpaper. Also clean the little prongs by the fly wheel.
Good luck
Aug 31, 2009 | Garden
Engine will not start, no spark
Try taking of the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs that are really close to the fly wheel. Use fine sand paper or emery cloth. Then check the spark plug wire for rust (clean if any). Try replacing the spark plug if it is old.
Let me know if this helps.
roundo4
Aug 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
