Question about Frigidaire FRT18FS6C Top Freezer Refrigerator
Fridge motor running all the time. Should it shut off when it reaches a certain temp?
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 01, 2010
Should fan run constant on indesit ban12fn fridge freezer?
It should shut off when it reaches the correct temperature. If you have the temp set to low it could cause it to continue to run or if there is an issue with the fridge that could also cause this issue. Keep in mind after a defrost it will take some time for everything to get back to the correct temp so it may run constant for a long time.
Jun 09, 2015 | Indesit Refrigerators
Why the fan in freezer shuts off
Pretty sure fan controls fridge temp, when fridge temp is reached fan shuts off.
Oct 11, 2014 | Refrigerators
Spa heateer run by Balboa 500Z control box. Standard mode will not shut off. Lowering temp to 88 still gets temp up to104.what is problem?
Sounds like the temp probe is not working or is disconnected. Temp going high, motor running means that it is calling for more heat which brings both the heater and the pump on until after set temp is reached. Once reached, heater will turn off and a few seconds later the pump will shut down.
Check connections for the temp probe. If connected make sure probe is where it should be. If it is, might try to replace it before considering the control board.
Aug 25, 2012 | Garden
Motor shuts down when reaching normal operation temp
Sounds like the mass air flow sensor or the air intake temperature sensor. Sometimes just wiping out the throttle body/air intake can make all the difference
Good Luck and Happy Motoring
Jun 22, 2017 | 2000 Dodge Durango
Why does my radiator fan on my 2000 alero not work all the time?
If its an electric fan they dont run all the time, a relay turns them on when the vehicle reaches a certain temp. once below that temp it shuts off. Hope this helps.
Mar 21, 2011 | Oldsmobile Alero Cars & Trucks
HONDA ODYSSEY 1995: WHERE IS RADIATIOR FAN SWITH LOCATED ? TROUBLE : FAN NEVER STOP EVEN WITH MOTOR OFF.\r\nSO, BATTERY GET DRAINED. THANKS, Charles from Québec, Canada
the fan is supposed to remain on until the engine temp falls to a certain temp. your problem is with the monitoring circuitry that is supposed to tell the fan to shut off. same circuitry leaves the fan off on start up until the engine reaches a certain temp.
Dec 13, 2010 | 1995 Honda Odyssey
Left freezer open for 4 days
Yes. Every thing will run and the only time unit will shut off is when it reached auto defrost. Door open will just not let temps reach normal ranges. There is no protection for this.
Jul 05, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
My dometic fridge, (3 Way) for the past couple years takes quite a while to reach it's normal operating temp. I'm talking anywhere from 10 to 15 hours. Once it reaches it normal temp it stays cold until we...
Have you tried running it without the fan? I know it sounds funny but it has to get hot (outside the fridge) to get cold inside. Shut fan off and see what happens. Also, keep in mind the more items you put in it that are already cold, or frozen, the faster it will cool inside the fridge. Also take a look up the back of the fridge, with outside cover off to make sure no big wasp nests or similar up there. May need to remove cover at roof and look down if you can't see too good from back of fridge vent.
Jun 21, 2010 | Dometic RM2652 Refrigerator
Air difusser between freezer and fridge will not stop running
When things like this happen I usually replace the main electronic circuit board which would control the motor operation timing, etc.
Nov 29, 2008 | Whirlpool Refrigerators
Fridge "runs" constantly
unit should shut off when temperature reached ie compressor and fan stop.
condensor is just a grid of pipework
heater only comes on when in defrost cycle
Jul 12, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Frigidaire FRT18FS6C Top Freezer Refrigerator Logo
89 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
