Question about Pentax Optio 30 Digital Camera
Camera will not turn on even with new batteries
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 02, 2010
  • 1 more comment
  • billbragg200 Sep 02, 2010
    unfortunately it did not work--thanks for your time and effort--bill
I can't turn on my new fujifilm finepix s4500, even with new batteries
Take it back to the store and tell them it probably something the company did work.
Oct 18, 2012 | Fuji FinePix 4500 Digital Camera
Won't turn on
possible battery problem. look at battery contacts. clean w/ pencil ereraser or small scraping devise.GENTLY, on battery and camera.
possible dead battery even if new.even if you buy a new battery, clean ththe contacts an battery and camera.
Sep 25, 2012 | Kodak EasyShare DX6490 Digital Camera
HI GOOD DAY I CANT TURN ON MY CAMERA IT DOESNT WORK EVAN WITH NEW BATERY THANKS
Check to make sure the batteries are inserted correctly.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.Close the [Memory Card / Battery Cover] securely, and then turn the power on.
If your camera still does not work even after you have performed the above procedures, your camera may be malfunctioning. Please have the camera serviced in this case.
Apr 19, 2011 | Canon PowerShot A460 Digital Camera
I have a Canon powershot A1100is dig camera. When I try to turn it on, it reads need new batteries. even if I change the batteries. Sometimes it wont even turn on. Help
Do you using Ni-MH batteries? Canon cameras judge the battery is low power by the real-time voltage of the batteries. And the voltage of Ni-MH batteries are lower than Li-ion ones, so the camera will notice low power even there are new batteries. Try Li-ion ones and see is anything help. best wishes!!
If you will use of a special battery, please come to our online shop for digital camera batteries
Feb 21, 2011 | Canon PowerShot A1100 IS Digital Camera
Will not turn on even with new batteries
Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 18, 2010 | Kodak EASYSHARE Z1285 Digital Camera
Won't turn on even with new batteries
Clean the battery contacts inside the camera with a cotton swab lightly dampened with rubbing alcohol.
Dec 17, 2009 | Pentax K100D Digital Camera
My camera won't turn on, even with fresh batteries.
u need not get new camera.use an iron metal to sctrach the bateery terminal of the cameral then put the battery.
Dec 09, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My camera will not turn on. I bought a new battery and even tried charging it. there has never been any damage to it.
try cleaning the battery posts both in the camera and on the new battery a finger mark on the battery terminal posts can stop a camera working but do fully charge that battery before you use it
Oct 23, 2009 | Kodak Easyshare M753 Digital Camera
Cannon s1is turns off even with new batteeries
Try lithium batteries. Sometimes regular batteries even when new cannot run a digital camera.
Jan 09, 2009 | Canon PowerShot S1 IS Digital Camera
Ixus 75 battery discharges overnight even if the camera is turned off.
That's it, the battery's defective, it's not the camera...unless you've tried another (new) battery...
Sep 27, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Pentax Optio 30 Digital Camera Logo
46 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
