Question about Kodak EasyShare M853 Digital Camera
Lense error 103 1 1 0 - Kodak EasyShare M853 Digital Camera
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 01, 2010
What is the following error code 103-372
103-372: IOT sc S/W Fail
An error is caused when processing the software in ESS PWB, and the process cannot be continued after that.
Replace ESS PWB
(Electronic Sub System Printed Wiring Board)
Oct 14, 2015 | Office Equipment & Supplies
Tip
Error code 103
hi...
i had installed the AVS video converter ,but it shows error codes 103.what can i do?please tell me.
on Feb 05, 2008 | Microsoft Windows Vista Ultimate Edition
Error 103 show up when I am playing Farmville, again and again! I dont know what it mean!
Try these troubleshooting steps:
Turn Files Sharing Off for your System Drive
Recover Registry Damage
Turn Windows Firewall Off
Reset Modem/ Router and try HTTPS instead of HTTP in URLs
Fix registry errors
If problem is not resolved yet then download error 103 repair tool like Reginout
Mar 09, 2013 | Google Chrome
Error 103 headlift error fargo hdp 5000
erro 103 could cos by head voltage erro or head fit erro.
this could be a problem with the printhead lift or transfer roller headfit.
reset the printer and try again ...
Jan 05, 2013 | Fargo HDP5000 Thermal Printer
How do you properly clean the lense of a discover Bausch and Lomb 60mm telescope?
ONLY the outside surfaces should ever be cleaned. Follow these directions:
http://www.televue.com/engine/TV3_page.asp?id=103
Jan 01, 2011 | Bausch and Lomb Discoverer 78-1600...
Dlink router error 103
i cant open any video online , like see any movies or and signal online , it is give me erroe 103 how i can do it
Jul 03, 2009 | D-Link DSL-300T Modem
7735
What are you tring or want to reset? Try the rest botton on the control pannel. Or give some more info. like the error code being displayed, then I may be able to help.
Mar 04, 2008 | Panasonic FP-7735 Black and White Copier
IBM RISC 6000 Error code
POWER supply failed or FAN failure 888-103-409-094
Aug 30, 2007 | IBM RS/6000 7013 (57FTOJ50) Server
Printer C760
This error normally requires a service call. However, certain rare occurrences, such as a stray static discharge in the vicinity of the printer or a power fluctuation, can cause a false 103 ITU error message to appear. If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Aug 13, 2007 | Lexmark C760 Laser Printer
Kodak EasyShare M853 Digital Camera Logo
112 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
