My sony vaio has a virus and will not allow windows to start. the computer turns on and asks how id like to restart the computer "with safe mode" or "last known configuration", but no matter what i choose the computer restarts and asks the same question. how do i reset it to factory settings right when i turn the computer on? ive done it before using one of the F buttons, but dont remember how.
  • 27,725 Answers
First test your CPU then tast all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 01, 2010
What to do to reset window on a vaio 652l notebook?
open it in safe mode and then shut down Windows. Restart computer. if it happens again go may need to restore the windows to a previous point if something has upset windows to make it go into safe mode
http://windows.microsoft.com/en-au/windows7/restore-system-files-and-settings assuming you have windows 7 as operating system
May 05, 2014 | Sony VAIO PCG-652L Laptop Charger...
Locked up on restart... How do I solve this mess????
Sony's Vaio line of laptop and desktop computers ship with the latest version of Windows installed. Even the best designed Vaio computer can sometimes malfunction, occasionally in connection with an error in Windows. Boot your Vaio computer in Windows' "Safe Mode" to disable potential problem-causing drivers and programs to help you troubleshoot and fix your Sony computer.
Windows XP Press the power button on the Sony Vaio computer, typically found in the top right corner of the laptop's keyboard panel or on the desktop's tower. If your computer is already on, press "Start" in the lower left corner of Windows XP and press "Turn off computer." A new window will appear. Press the green "Restart" icon. Hold down the F8 key on your Sony Vaio's keyboard as soon as your computer's screen goes dark. A new window, labeled "Windows Advanced Options," will appear. Choose one of the Safe Mode options listed. "Safe Mode" loads the minimal amount of drivers, while "Safe Mode with Networking" also loads your networking preferences. Press "OK." b> Windows 7 Press the Sony Vaio computer's power button if it's off, or restart the computer. Click "Start" in the lower left corner of Windows 7 and choose "Shut Down." A new window will appear. Push "Restart." Press and hold your computer's F8 key. A menu called "Advanced Boot Options" will launch on the screen once the restarting process is complete. Choose "Safe Mode" or "Safe Mode with Networking" and press "OK."
You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 15, 2013 | Computers & Internet
Sony vaio all in one touchscreen stopped working
XP and Vista Normal Mode Start your computer as you normally would. Click the "My Computer" icon on your desktop. Go to "C:\ Program Files\Sony\Setting Utility Series." Find and choose the "VCCPointingDevice" folder in the "Setting Utilities Series folder" to open the "Built-in Pointing Device" dialog box. Locate the "Enable" box on the "Built-in Pointing Device" dialog box. Check the box to enable the Vaio touchpad if you wish to use this device. Disable the touchpad if it is interfering with the external mouse. Uncheck the "Enable" box if you have a USB (PS/2) mouse connecting to your Vaio and wish to use that instead of the built-in touchpad. Pick "Yes, I'm Sure" when prompted to activate your choice, then close all the windows. Windows 7 Normal Mode Launch Windows as usual. Go to "Start" > "Control Panel" > "Mouse" > "Pointing Device" to open the Vaio touchpad control center. Uncheck the "Enable" box on the "Pointing Device" window when you wish to use your external mouse. Check the "Enable" box on the "Pointing Device" window when you want to use the Sony Vaio touchpad. Make sure the external mouse is not interfering with the touchpad if you have one connected. If so, unplug the mouse from your computer. Click the "OK" button at the bottom of the "Pointing Device" window. Close all other windows. XP and Vista Safe Mode Restart your computer. Press the F8 key before the Windows welcome screen appears to enter Safe Mode. Click "Start" > "Control Panel" > "Add/Remove Programs." Find and delete all software for mice and pointing devices. Restart your computer in normal Windows mode. Proceed to next step if the problem persists. Restart your computer in Safe Mode. Right click the "My Computer" icon on the desktop. Choose "Properties" on the drop-down list. Pick the "Device Manager" tab in the Properties window. Select the "Other Devices" folder and click on the "+" sign besides it. Delete all the devices under this "+" sign by clicking on the "Remove" button next to each of the items. Restart Windows in Normal Mode. Once Windows is operating, there will be a "New Hardware Wizard" pop-up that will load all the necessary drivers for the touchpad, mouse and other pointing devices. This should fix the corrupt driver for your Vaio touchpad. Windows 7 Safe Mode Reboot your computer and press the F8 key before the Windows welcome screen appears to enter Safe Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Click the touchpad icon. Choose the "Driver" tab and press the "Uninstall" button. Press the "OK" button to confirm. Restart Windows in Normal Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Choose the "Driver" tab and press the "Update" button. Press the "OK" button to fix the touchpad software.
http://esupport.sony.com/perl/swu-list.pl?mdl=PCGFRV26
Feb 08, 2013 | Sony VAIO Computers & Internet
Sony vaio touch screen stopped working
Feb 08, 2013 | Sony VAIO VGC-LV180J 24-Inch All-in-One PC...
TOUCH PAD NOT WORKING
The Sony Vaio laptop is typically sold with a touchpad device installed below the keyboard. The touchpad is for navigating the screen and is used like an external mouse. A touchpad can sometimes malfunction for no apparent reason, but there are ways on troubleshooting the device yourself before asking a technician for help. Start your computer as you normally would. Click the "My Computer" icon on your desktop. Go to "C:\ Program Files\Sony\Setting Utility Series." Find and choose the "VCCPointingDevice" folder in the "Setting Utilities Series folder" to open the "Built-in Pointing Device" dialog box. Locate the "Enable" box on the "Built-in Pointing Device" dialog box. Check the box to enable the Vaio touchpad if you wish to use this device. Disable the touchpad if it is interfering with the external mouse. Uncheck the "Enable" box if you have a USB (PS/2) mouse connecting to your Vaio and wish to use that instead of the built-in touchpad. Pick "Yes, I'm Sure" when prompted to activate your choice, then close all the windows. Windows 7 Normal Mode Launch Windows as usual. Go to "Start" > "Control Panel" > "Mouse" > "Pointing Device" to open the Vaio touchpad control center. Uncheck the "Enable" box on the "Pointing Device" window when you wish to use your external mouse. Check the "Enable" box on the "Pointing Device" window when you want to use the Sony Vaio touchpad. Make sure the external mouse is not interfering with the touchpad if you have one connected. If so, unplug the mouse from your computer. Click the "OK" button at the bottom of the "Pointing Device" window. Close all other windows. b> XP and Vista Safe Mode b> Restart your computer. Press the F8 key before the Windows welcome screen appears to enter Safe Mode. Click "Start" > "Control Panel" > "Add/Remove Programs." Find and delete all software for mice and pointing devices. Restart your computer in normal Windows mode. Proceed to next step if the problem persists. Restart your computer in Safe Mode. Right click the "My Computer" icon on the desktop. Choose "Properties" on the drop-down list. Pick the "Device Manager" tab in the Properties window. Select the "Other Devices" folder and click on the "+" sign besides it. Delete all the devices under this "+" sign by clicking on the "Remove" button next to each of the items. Restart Windows in Normal Mode. Once Windows is operating, there will be a "New Hardware Wizard" pop-up that will load all the necessary drivers for the touchpad, mouse and other pointing devices. This should fix the corrupt driver for your Vaio touchpad. b> Windows 7 Safe Mode b> Reboot your computer and press the F8 key before the Windows welcome screen appears to enter Safe Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Click the touchpad icon. Choose the "Driver" tab and press the "Uninstall" button. Press the "OK" button to confirm. Restart Windows in Normal Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Choose the "Driver" tab and press the "Update" button. Press the "OK" button to fix the touchpad software. Hope this help.
Jan 16, 2013 | Sony Nice Vaio Pcg-81312l Laptop Notebook...
I have a sony vaio CS series , Flickiring screen
try to restart in safe mode by tapping f8 while restarting the computer
Select safe mode and select "safe mode"
Jul 29, 2010 | Sony VAIO VGN-CS118E/P NoteBook
Unable to have safe mode screen come up from hitting f8
When the F8 key doesn't work, there is another (less desirable) way to force the computer to start up with the option screen to go into safe mode is to interrupt the Windows start-up process. As soon as the Windows screen comes up showing that it is booting up, remove the power from the computer. When you restart, Windows will detect that it did not start up correctly on the last attempt and will automatically go into the option screen to allow you to choose Safe Mode.
Feb 22, 2010 | Sony VAIO PCV-RS710G PC Desktop
Restarting again and again...
your computer is virus infected.
Scan your computer with latest updated antivirus and maleware removal
in safe mode.
May 24, 2009 | Sony VAIO Notebook
Sony vaio not loading windows
reinstall the OS ! Just overrite it over the previouse xp so u won;t lose data ...
..most probably u are missing some files ... .. or u have virusez issues. Ofecourse there is the posibility of hardware mallfunction, but considering microsofts reputation ... probably thats not the issue ...
Dec 10, 2008 | Sony VAIO PCV-V210P PC Desktop
Windows will not start up
choose start windows in Safe mode, if it starts then everything will look big, don't worry about that for now. Then go to Start>accessories>system Tools>system restore and choose a date when you know that everything was working normally, when it has finished restoring the computer will restart. If asked choose start windows normally.
I hope this helps
Nov 25, 2008 | Sony VAIO V2M (VGCV2M) PC Desktop
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
