Question about Samsung Digimax S730 Digital Camera
The memory card is staying locked even though I unlock it
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 02, 2010
I am newbie, I can not format my flashdisk as it is locked though I never locked it before. Many thanks
Hi Thanks for your question.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Thank You for using FixYa.
Jan 17, 2011 | Electronics - Others
Tip
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
on Jan 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
My kingston 4GB memmory card won't unlock, it came to me and i unlocked it with the the thing onthe side of the card and on my camera it says its still locked even though it is unlocked ?
its just a memory card problem dear....
u can do this simple...just open the memory card with your hands and see where that thing is connected....it will be not corrected properly...
you can connect it with your knowledge easily...
Jan 14, 2011 | Kingston 4GB Secure Digital High Capacity...
I have not been able to get the write protection removed even after unlocking the memory card
Jan 12, 2011 | SanDisk 2GB microSD Memory Card
The memory was lock. but i want to unlock it
id1102_e3sdhc.gifSOLUTION 1 - Unlock the memory card.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Dec 30, 2010 | SanDisk 4GB microSD High Capacity Memory...
My 7610 supernova memory card has been locked how do we get it unlocked
We enable a password security on our Nokia phone to keep the data on the memory card private and not accessible to others. However, many times you may have come up across a situation wherein you have completely forgotten the password of the memory card or simply the access to the memory card is denied.
Even though you have tried your best to come up with all the combinations of the passwords that strike in your mind but all your efforts seems to be going in vain. Instead of panicking in such a situation, you can stay calm and perform a few troubleshooting steps to access the phone’s memory card.
One of the easiest ways to unlock or access a blocked memory card of your phone is to rename the memory card. Here are the steps you can take to rename the phone’s memory card:
  • On your Nokia phone, press the Menu button and go to Gallery> Memory Card (Please note the location of the Memory Card on the phone’s software may vary with different models).
  • Do not open the Memory Card folder but only highlight it and then select Options > Rename and put a new name to your Memory Card by replacing the old name and press OK.
  • Restart the phone and you will be able to access your cell phone’s memory card easily.
Sep 11, 2010 | Nokia 7610 Supernova Cell Phone
My memory card suddenly says locked, why and how do I unlock it
Thanks for using Fixya.
(i) Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.9632f20.gif
(ii) Toggle the lock switch.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 06, 2010 | SanDisk 1GB microSD Memory Card
HP photosmart m525 camera.....card is locked
Please try to format your card on computer and then use it....
May 29, 2009 | HP Photosmart M525 Digital Camera
I recently bought the camera and was able to take 45 pictures without a memory card. I then put a memory card in from my phone and it allowed me to take pictures. However, once I took the card out and...
Be sure that the Lock switch on the memory card in your camera is set to unlock. If it is unlocked then try and see if you can reformat the card with the camera.
Jun 10, 2008 | Samsung Cameras
Samsung Digimax S730 Digital Camera Logo
44 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
