Question about Kenmore 54501 Dehumidifier
I have a Kenmore Dehumidifier Model # 580.53509300 that it runs but it won't pull out any water. What can I do to fix it?
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 01, 2010
  • 1632 Answers
SOURCE: motor runs on dehumidifier but doesn't collect water
If it doesn't get cold change the temperature,
Put the float wire up.
finally it is out of r-14- freon.
Vitally
Posted on Jun 02, 2009
22yooper
  • 828 Answers
SOURCE: Dehumidifier Error?
Your bucket full switch may be defective. If you are capable, bypass it since you are draining to another place other than the bucket.
Posted on May 09, 2008
SOURCE: Kenmore 580-52650100 65 pts./24 hour
Humidifier is fairly old. I put it on the curb for garbage pickup.
Posted on Apr 29, 2009
  • 59 Answers
SOURCE: kenmore dehumidifier is running but not pulling water
normally this means that the compressor is not running. Check capacitor and connections to compressor.
David
Posted on May 25, 2009
dmftrucker
  • 1922 Answers
SOURCE: A one year old Kenmore dehumidifier model
these units are notorious for losing their refrigerant charge,if the compressor isn't running that is one reason why, have a gauge put on the system to see sealed system pressures otherwise the low-pressure switch could be bad,you can test this with a continuity meter
Posted on Nov 14, 2009
The dehumidifier runs, but does not collect water in its reservoir. (the lights all light up, it cycles on and off, but all it appears to be doing is running the motor - not actually functioning.) And,...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 22, 2011 | Kenmore 54701 Dehumidifier
Dehumidifier runs but extracts no water at all. room is 65degrees & humidity is 75%. no frost on coil & no moisture either. kenmore model no. 580.54501.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 15, 2011 | Kenmore Dehumidifiers
Our dehumidifier is no longer pulling moisture out of the air. I took the back off and the fan is still running. So motor or condenser? And is it worth fixing? The machine is approximately 6 years old.
heatman101
Nov 28, 2010 | Kenmore 54501 Dehumidifier
Dehumidifier seems to run but does not pull any water. THe electronics work fine. THe unit will run, turn on and off but never gets any water in the bucket
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 01, 2010 | Kenmore 5245 Dehumidifier
Our Kenmore dehumidifier (Model 580.53650200)runs but no water collects in the reservoir bucket. What could be wrong?
heatman101
Sep 18, 2009 | Kenmore 5365 Dehumidifier
I have a kenmore dehumidifier model 53701 and it has been working fine, but now no water is collected even though its running. what gives?
heatman101
Jul 14, 2009 | Kenmore 53701 Dehumidifier
I have a Kenmore 50 pint dehumidifier Model 580.54501400
It looks like it is simple to get the filter out but we are finding it to be imposible. How can we take it out. It doesn't just pull down.
Jul 09, 2009 | Kenmore Dehumidifiers
Kenmore Dehumidifier Model 580.52650 Says "Bucket Full" - Wrong
the problem is with the switch which is connected to the float arm, try pulling it manually, it shoud turn on and off your unit if working properly
Jun 14, 2009 | Kenmore 54501 Dehumidifier
My kenmore dehumidifier won't pull the moisture out of the air, the motor is runing when turned on but the bucket never fills up. What is the problem?
heatman101
Jun 10, 2009 | Kenmore 53509 Dehumidifier
Kenmore dehumidifier is running but not pulling water
David
May 25, 2009 | Kenmore 53701 Dehumidifier
Kenmore 54501 Dehumidifier Logo
317 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
