Question about Kenmore Elite 45986 Front Load Washer
My elite h4 washer will work then it just stops and wont do anything. the screen just has a "F" on it .. also has a bad odor when you walk by it. what do i do to fix this?
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!##$$
Posted on Sep 28, 2010
Refrigerator Odor
Remove all the food from the unit and clean it with a diluted chlorine bleach solution and let dry and then do it one more time. Also get a box of baking soda and put it in the fridge to absorb odiferous smells odors
Jun 30, 2017 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Tip
Odor from your towels or clothes washer?
With newer higher efficiency washing machines flooding the market today, new issues arise. One annoyance is odor of mildew on towels or coming from the front load or even top load machines.
With a little maintenance and care this trouble can be eliminated and avoided in the future.
If you currently have the odor locate one of the following products
- Affresh
- Smelly Washer
Run the hottest cycle without clothes and the product you chose. If the washer is especially bad you may need to run a second clean out using another dose.
After the washer is clean be sure you only use the recommended detergent for your product. HE detergents are required for most all front loading machines and a lot of new top loading machines too. This is very important, because if the wrong type is used it can cause build up in hidden areas that will cause odors as well as performance issues and even premature failures of components.
Do not use any additives that are not recommended for your machine, check with the manufacturer or owners guides for specifics.
Leave the lid or door open at least partially when not in use, this will move air through the unit to help keep odors away.
Use the Affresh or similar product once a month in the machine to keep anything from building up where you can't see.
Other washer issues:
SUDS http://www.fixya.com/support/r4621260-many_suds_in_clothes_washer
Wont Stop Filling http://www.fixya.com/TipsAndTricks/preview.aspx?thid=4621172
Control Locked http://www.fixya.com/support/r4624473-control_locked
on Apr 23, 2010 | Washing Machines
We have a kenmore elite he h4 washer and it flashed f 02 then stopped working it wont spin
This is what done.
1. Unplug the washer
2. Take of the toe panel in the front by removing the three screws.
3. Get a bunch of towels (I mean a bunch!!!)
4. The pump is in the center, and it has a plastic grip handle that one can unscrew to remove the filter. As you unscrew it, LOTS of water will come out. Be ready with the towels. A cookie sheet helps to collect the water too.
5. Clean the filter assembly.
6. If one wishes to check the inlet of the pump, remove the back panel, about 12 screws. (Note, the following works for replace the pump as well)
7. Remove the large bellow from the bottom of the tub that goets to inlet of the pump by removing the clamp
9. Lift up on the plastic cover that covers the wires that power the pump. There may be a small plastic catch that is lifted up as to allow the connector to become free.
8. Remove the Torx screw that holds that is the center just under the filter screen.
9. Pull the pump forward.
10. Unclamp the pump outlet hose.
11. Remove pump
12. Unclamp the large bellow on the pumps inlet and inspect for debris.
13. Clean pump and fitler w/o getting water on the pump.
14. Install in reverse order. Remember, it is much easire to put the inlet bellow and outlet hose on the pump before you put into the washer
Oct 10, 2010 | Kenmore Elite HE5t Washer
I OWN A KENMORE ELITE OASIS HE TOP LOAD WASHER AND I AM HAVING PROBLEMS WITH RUNNING A FULL CYCLE WITHOUT HAVING TO ADJUST THE LOAD A F 51 CODE APPEARS AND THE MACHINE STOPS. PLEASE TELL ME WHAT I NEED TO...
F51 MEANS BAD READING ON THE RPS SENSOR. COUPLE OF THINGS YOU NEED TO CHECK. IT'S A LITTLE COMPLCATED. IF YOU ARE A LITTLE MECHANICALLY INCLINE, I CAN WALK YOU THRU IT WITH WITH NO PROBLEM
BOYNISMO@YAHOO.COM 714-334-1998
Dec 06, 2009 | Kenmore Elite HE4 Electric Dryer
Do I need to secure the tubs inside Kenmore Elite Washer & Dryer?
Not the dryer but you do for the washer ... there is bolts that go in the back to hold the tub ... the bolts came with the washer went it was new... you may be able to get a set from sears...
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
My washer wont spin run do anything says f 55
It's a control board issue,this unit is made by Whirlpool,they are repairing a lot of theirs for free,so you may want to call Sears and see if they are covering theirs also.
Sep 13, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite flashes f1 code and stops
If I remember correctly? It is stopping after the wash cycle and won't spin? If this is correct you need a new pump. I found out that front load washers have a filter that is behind that front cover and it needs to be cleaned every 6 months or more often if you have lots of strange items that show up in the wash like coins or toys or if you have lots of furry pets. Mine did that with out the code and I replaced the pump and check the drain every 6 months or so. I was told a good indicator that the drain filter is getting clogged is when your washer has an odor. Just a rule of thumb.
Jun 15, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
54 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
