Question about Refrigerators
HELLO, I'M WORKING ON A THREE DOOR L.G REFER, I AM GETTING A SLIGHT FROST BUILD UP ON THE RIGHT SIDE BY THE FREEZER DOOR RAIL AND ON THE TOP RIGHT CORNER OF THE EVAPORATOR COVER. GASKETS ARE SEALING GOOD, I DONT HAVE A DEFROST PROBLEM, THERE IS GOOD AIR FLOWI WAS WONDERING IF L.G IS HAVING A MOISTURE PROBLEM.IF SO WHAT IS THE FIX? BUT FOR RIGHT NOW I TOLD MY CUST TO CLOSE FREEZER DOOR ,PUSHING ON THE CENTER OF THE DRAWER TO ENSURE ALL FOUR CORNERS ARE SEALED AND THE FREEZER DRAWER DIDN"T SHIFT SLIGHTLY AND ALLOW AIR TO ENTER, THATS EXACTLY WHAT IT LOOKS LIKE. BUT WOULD LIKE YOUR OPINION. THANK YOU L.G. MOD#LFX28977ST/01
  • 2 more comments
  • papaduck2008 Sep 01, 2010
    I SUSPECTED AS MUCH, AND THE WAY THE DOOR IS MOUNTED IS CHEESY AT BEST.
    WOULD LIKE OTHER OPINIONS FROM OTHER TECHS IN FIELD
  • papaduck2008 Sep 02, 2010
    THANK YOU FOR INPUT. I TOLD THE CUST THAT IT LOOKS LIKE THE DOOR WASN'T CLOSED CORRECTLY FOR A TIME AND IT LET MOISTURE IN. THESE NEWER APPLIANCES ARE NOTHING TO BRAG ABOUT. ITS A SHAME THEY DON'T TEACH COMMON SENSE IN ENGINEERING SCHOOL. I LIKE WHAT YOU SENT ABOUT THE REFER SOLD WITH NO EVAP FAN BLADE,.....QUALITY STUFF. THANKS AGAIN FRED.
    YES, IT CONFIRMED WHAT I HAD SUSPECTED.
  • Refrigerators Master
  • 3,083 Answers
I read about a moisture reduction switch on this unit, perhaps it needs tweeking? Scratch that, another blog said it's an external control, then another said it was a temperature control, and I couldn't find any more information on it. I'm inclined to think that there is a sealing or freezer door problem also, since the problem isn't that bad, just a nuisance. Didn't see any reports of a moisture problem on the net, so no suggestions. I'm wondering if the door was slightly obstructed from closing for awhile, allowing too much moist air in? Or perhaps something too warm that emitted humidity.
Found some dissatisfied customers on a lot of blogs, but no report of this exact problem.
Here was one interesting example from lg.com reviews:
"I bought this model 4 weeks ago. It was delivered & set up by the store and never got cold. The store took it back and delivered another unit. Everything on it worked fine, except the icemaker. It never made any ice. so I called for service. They came right away, and ordered some parts. After parts were shipped the service guy opened a compartment in the freezer to replace a fan motor, and found that the motor had been put in without a fan blade. He replaced it and now it works fine. After these 2 problems I really wonder about quality."
This problem sounds like the one you're having, actually:
"We have had many problems with this LF Frig. The technician and a factory rep had to come out several times because of frosting issues. The doors do not seal well. the cold water dispenser stick and water runs on the floor. I am sorry we bought it. We are stuck with it for probably 10 years. I hate it."
Looks like you're right about the doors.
Good luck, and hope that helped. Please rate this answer if it helped you.
Posted on Sep 01, 2010
  • Tom Carson
    Tom Carson Sep 02, 2010
    You're welcome for the attempted help on this difficult problem, Fred. Good luck with this tricky situation- it's problems like these that really make your month, I know!
  • 1,711 Answers
If as you have mention that fan serculate good and their in not any defrost problem then,
You have already estimate correctly, their is probably a seal proplem and air entering freezer, probably door magnetic gasket, but also door bending problem so it dous not close proberly.
You can confirm it by air tight sealed the freezer using a secure tape around the door and check it out after 24 hours.
If it the ruber mangetic seal it is rather deficult to be replace and need special experiance.
If the door have a slight bending then you try to udjust a litle bit the door hinges this can help a lot.
Amana bottom freezer unit warms, then resets after being left unplugged
If the door does not shut correctly, humidity enters the unit and condenses inside. The defrost function is not designed to work properly under such a condition.
Ice (frost) builds up around the cooling coils, and actually insulates them, so you don't get good cooling. When you unplug the unit, the frost melts, runs into the bottom tray beneath the unit (can't see it).
When you turn it back on it cools like it should until the frost builds up again. You need a good gasket and a door that is adjusted properly. You also need the unit level at least side to side, but front to back also is preferable.
The unit has front leveling feet, and the back usually adjusts itself with self-leveling feet. The adjustments for the door are metal bars inside it, behind the inside storage panel.
The hinges are also adjustable. Sometimes the door sags from heavy things stored inside it. You must loosen the hinges a bit, lift the door and hold it while you tighten the hinges.
Sometimes the unit can be unsalvagable, because it's been situated incorrectly for so long that it's permanently bent out of square.
OR, the defroster clock might be bad.
Jan 20, 2014 | Refrigerators
Samsung french door freezer gets lots of frost inside - we've replaced the gasket but still get frost
Could be the rail slides not closeing correctly keeping door open slightly. Also they have made a new stronger set of rails to be used. Try going to the Samsung web site for tech info our recalls for that unit
Aug 18, 2012 | Samsung RF265AA Bottom Freezer French Door...
Frost and ice are building up on the right side of the freezer drawer, including the tracks. I can chip it away and get rid of it but it just comes right back. The air vents do not seem to be blocked.
Hello, Make sure there is no leak at the door gasket! This is the most common reason for this type of frost in the freezer on drawer and racks. Make sure the gasket is sitting flat and not damaged.
Jun 27, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
I have frost building in front of the face plate covering the interior light and at the door were it meets when it is closed, also it is building slightly to the left where the sticker is placed by the...
Hello there
Here is a couple of things that need to be checked fully ok
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try: If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
Nov 11, 2010 | Kitchen Ranges
Frost building up in ice maker exit shoot and
Look into the dispensor , and see if the door flap is closing , or letting warm air in which will cause the frost buildup . If not closing completely , remove the top cover on the freezer door hinge , and unplug the plug . This will remove power to the door . Use a small screwdriver , and insert under the freezer door dispensor control board , and pry outward . Remove the 3 plugs on the board . Next , remove the 4 screws holding the white dispensor cover , and slide outward . At the top right , you will see a solenoid and plunger , which control the door flap . Usually , this plunger rusts on the solenoid . Replace both , the solenoid and plunger ( come together in kit ) Pt # WR62X10055 . Re-assemble in reverse .
Oct 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Excessive frost build up inside the freezer
Your problem is not a recall it is the fan and how many items you have in your freezer. Is it stuffed pretty full?
Jun 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Fridge part of product is not working
i have a admiral serial # 1142843us, model # hmg211771. freezer at top freezes. hot at bottom. motor sound like it roars. frost inside frrezer at top.
Apr 09, 2009 | Refrigerators
Freezer keeps running
yes,you need to pull the front panel on the ice maker off to get to the solinoid that opens and closes the flap,with the flap vranked open you are letting cold air out and warm air in and that makes frost,if you don't want to try and fix it your self put a cloth towel in the chute to block the air lose and call an honest local appliance repair person-mike
Nov 15, 2008 | Whirlpool Refrigerators
GE side by Side Fridge
froggy, First check the back panel of the freezer section and see if you have a big frost build up. If so, you probably have a defrost problem, heaters more than likely. If there is no frost build-up check to see if the fan in the freezer (evaporator fan) is running. If that's ok, next would be the automatic damper. Have someone unplug the refer. Open the refer door and listen for the damper door to open when someone plugs the refer back in. If thats operational, next would be the thermistors, you would have to ohm them out to see if they are in range. Seldom is this the problem. Check these things out and get back on what you find. Catriver..post back.
Apr 03, 2007 | GE GSS20IBPWW / GSS20IBPCC Side by Side...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
