Question about Amana ARS2464B Side by Side Refrigerator
I have side by side and can not get the ice maker to work. I can get water though.
  • 4 more comments
  • leeprocraft Sep 01, 2010
    There is ice in the tray just sitting there. I replaced the solinude about 2 years ago. another thing I forgot to mention is the freezer isn't freezing like it should. some thing are have frozen or soft. I have it set at 4
    the freezer isn't freezing everything either. I have it set at 4. the water in the ice tray is just sitting there. Its been about 30 mins. so far
  • leeprocraft Sep 02, 2010
    my freezer isn't freezing . temp is at 47 degrees. setting is at 5.5 is that why ice maker isn't making ice. water in tray isn't freezing
    compressor not too hot--compressor fan running-- fan inside freezer running-- took off lower panel inside freezer and there was frost on 2 uppere coils
    another thing, the temp. is only 47 degrees on the refrigerator side
    I will have to call a appliance man
  • Amana Master
  • 1,711 Answers
The posible problems are;
1. Their is a water compartment behind the drawers on the bottom in the fridge side this might be freezed. So you can use a hair dryer with a warm air try to melt the ice. If this is the case udjust the temperature setting a litle more higher not happen again.
2. The water filter is coggled so you must replace it.
3. Water line pressure is very low so water can not pass thought the fridge.
4. Water solenoid valve is ither faulty or coggled you need to check it.
Good luck
Posted on Sep 02, 2010
    President:
  • 3,773 Answers
30 years Experience in Home Refrigerator,Washer,Dryer, Repair
I would love to help you find a solution.
Leo Ponder
imufo2@sbcglobal.net
Posted on Sep 01, 2010
  • Leo Ponder
    Leo Ponder Sep 01, 2010
    I assume that you have water in door, if so this is a different solenoid than the icemaker.
    You can get water for drinking but no water at icemaker. Do this:
    Pour ice maker tray full of water, if it dumps ice after it freezes then you need to replace the
    ICEMAKER solenoid valve which means the drinking water valve too since they come together.
    If it doesn't dump ice cubes after it freezes then you need to replace the icemaker.(easy)
    The solenoid is the thing that the water line from the wall attaqches to in the back of ref.
    parts house can help tremendously if you ask when you purchase the water valve assembly.
    Imufo2
    Leo Ponder
  • Leo Ponder
    Leo Ponder Sep 02, 2010
    O.k Lets check the defrost system if it's not freezing that definitely the problem with the icemaker.
    Do This:
    First put your hand on the compressor. if its too hot to touch very long then there is a compressor problem or condensor coil restriction
    Is the condensor fan running next to compressor?
    Is the fan inside the freezer running?
    To check the Defrost system, remove the back panel inside the freezer and see if the coils are restricted by ice on the coils
    If It is a defrost problem since the ice that freezes on the freezer coils
    is not being melted by the defrost system.
    There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
    Its best handled by a Technician butyou could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info Also check evaporator fan in freezer If this was helpful please rate me
    IMUFO2
    Leo Ponder Appliance-Tyler,Texas
    imufo2@sbcglobal.net"
    Sergeant:
  • 252 Answers
Check the plugs behind it to make sure that they are properly plugged in. Then check to see if the on and off switch is on If all fails get your voltage meter and check at the switch to malke sure that it is getting the any voltage. trace the voltage all the way to the switch that works the ice dispenser. If you are gettin g voltage there go to the rotor motor to see if voltage is getting to the motor. The problem will probably be at the dispensor switch but corroded or faulty wireing could be the problem. If all the switches check out and you have voltage going to your motor. The motor could be bad.
Ice maker not working
What's the temp. in the freezer? Should be below +10F, otherwise you have a bad ice maker most likely.
Jul 18, 2012 | Hotpoint FFU00 Side by Side Refrigerator
Leak on the ice maker water supply
Good day,
The house water supply is connected to a dual water valve on the bottom rear of the machine. It splits there going to the ice maker and water in the door.
If the ice maker side is feeding water to the ice maker even though the ice maker is in the off position means the diaphragm in the valve is leaking and must be replaced. Very common problem.
Apr 11, 2010 | Refrigerators
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
ICE MAKER
Your ice maker works off a different side than the water dispenser. Most times the water control valve is the problem yet it has 2 sides one for water and the other for ice. You can check the ice maker by filling with tap water. Let it freeze and if it dumps the ice and tries to refill I would say the water control valve part number 4389177 will need to be replaced. Sea Breeze
Aug 24, 2009 | Whirlpool GD5SHAX Side by Side...
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
The in-door water stopped working. The ice maker still gets water, but there is no water coming out of the door dispenser.
You more than likely have a bad water valve. Unfortunately, the water valve is a double valve ,one side services the ice maker,the other side the water dispenser.Even though the ice maker is getting water the whole valve has to be replaced. Hope this helps
Jul 30, 2009 | Whirlpool ED2GHEXN Side by Side...
Ice maker not making ice
Water solenoid to ice maker not working. Check with ohm meter..should NOT read open
Water line to Ice maker frozen solid. Look at water inlet to ice maker....is ice present in line?
Evaporator coils frozen over with ice. Will cause water line to freeze and unit will slowly thaw.
Try unplugging the unit for several hours and see if it starts to cool normally again. If it cools normally then check heater element and Defrost Thermostat.
Nov 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
Amana ARS2464B Side by Side Refrigerator Logo
162 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
