Question about Southern Telecom Emerson Bluetooth Headset - Magenta Wireless Headset
I can not get it to hook up to my Blackberry Curve 8360? It keeps saying unable to pair?
    President:
  • 1,118 Answers
As you have not specified your headset's model, go to this page, select the one which better suit your needs, download it and follow the instructions on how to put your headset in pairing mode, prior to trying to pair it with your phone.
Hope you are able to sort your problems out soon.
Just my 2 cents...
Regards, Carlos
Posted on Sep 01, 2010
  • 9 more comments
  • lilbamagrl Sep 02, 2010
    it is a Emerson EM-277 and i have charged it for 3 hours and it still won't pair to my Blackberry Curve!!!!!
    it is a Emerson EM-277 and i have charged it for 3 hours and it still won't pair to my Blackberry Curve.
  • CARLOS R SOUZA JR
    CARLOS R SOUZA JR Sep 02, 2010
    Sorry that the page I pointed out doesn't provide the EM277's user guide. Anyway, many bluetooth headsets use to behave pretty much the same way. Starting with it turned off, press and hold the power button as if you were turning it on, but don't release the button until you notice that the indicator light is either steadily lit or alternately flashing in red and blue. It is in paring mode now. Only then, make your phone's bluetooth application search for new devices. After a while, you headset should appear on-screen. Make it connect. If a pairing code (or PIN, or passkey), is requested, enter either '0000' (four zeros), or '1234' (all without the quotes). Your headset's light will flash and it will enter the stand-by mode.
    Hope one of these codes works for you.
    Regards,
    Carlos
Cannot pair blackberry 8520 with parrot ck3100
I could not pair the Blackberry Curve 8520 with the Parrot CK3100. After looking at the Parrot website, I saw that the Blackberry was actually supported, so it SHOULD work.
Then I found the solution: the Parrot had already too many other phones paired (4 or so), so it could not pair an additional one. After removing the other phones from the Parrot pairing list, the Blackberry paired without a problem. SOLVED!
Davy
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
IM TRYING TO CONNECT MY JWIN BLUE TOOTH TO MY BLACKBERRY CURVE 8530 AND IT WILL NOT LET ME CONNECT. IT SAYS THAT NO BLUE TOOTH IS FOUND. HOW CAN I PUT MY BLUE TOOTH IN PAIRING MODE AND THEN CONNECT IT TO...
When the bluetooth is off press it's button and keep it presed until the led is lighting red. Then the bluetooth is in pairing mode. Relase the botton and start the search for devices on your blackberry and use pin 0000 to connect. Good luck.
Jan 27, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
I have a Blackberry Curve 8320. I purchased a Motorola Universal Bluetooth Headset H620 that is supposed to be Blackberry compatable. I am unable to get my phone and bluetooth paired. What do I need to...
It may be the pairing code that you are using. Usually it is 123, 0000, 1111, 1234, or some other variation.
Make sure, also, that you are in pairing mode with the headset. If you can scan via bluetooth and detect the device, then it should be ready to pair.
Nov 02, 2009 | AT&T Blackberry Curve 8300 Smartphone
Trying to pair a h12 bluetooth to the 8330, asks for numeric pass key. i have tried 0000 and 1234 it says unable to pair
Is the blackberry in pairing mode? Is the earpiece in pairing mode? They both need to be set. Four zeros should be the passkey.
Oct 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
I am trying to sync a new bluetooth (sprint brand) to my blackberry curve 8330 I have bluetooth enable and have searched to locate the bluetooth earpiece and it keeps saying can't be found
You have to make sure the bluetooth is in a pairing mode for the blackberry to discover it on most bluetooth they have a pairing button turn off your bluetooth headset hold pairing button till the light is solid or flashing red and blue depending on model then search for new should find it
Sep 24, 2009 | Cell Phones
Blackberry Curve 8310 won't pair!
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
Jul 26, 2009 | Blueant Z9i Bluetooth Headset
Blackberry Curve 8330 can not find my bluetooth headset
Turn the 360 off.
Then turn Bluetooth off, then back on the Curve.
Then turn the 360 back on, input the code when asked to due so.
Jul 23, 2009 | RIM BlackBerry Curve 8310 Smartphone
Motorola hs850 bluetooth headset won't pair with Blackberry Curve
try to delete it out of ur phone all the way and then try to pair it again
Dec 15, 2008 | Motorola Mobility HS850 Consumer Headset
H500 won't pair with Blackberry Curve
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
Nov 08, 2007 | Motorola Mobility H500 Wireless Headset
Southern Telecom Emerson Bluetooth Headset - Magenta Wireless Headset Logo
276 people viewed this question
Top Southern Telecom Radio Communications Experts
shaun taylor
janman
Are you a Southern Telecom Radio Communication Expert? Answer questions, earn points and help others
