Question about Intel Motherboard
Windows xp installation
Whe installing windows xp in hp intel laptop, the hdd is not connected. It ask driver file for ide. but if I install windows vista the hdd is connected. what propblem? If you have a driver file for IDE Please Give me.
Thanks
  • 34 Answers
Hello
what is the model number of your notebook.
Thankyou
Posted on May 10, 2008
I cannot connect SATA HDD
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 26, 2013 | Computers & Internet
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
Oct 08, 2012 | Computers & Internet
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
XP installation problem - HP Cpmpaq 6720s Laptop [HDD detection error]
The hard disk is not detected because this model notebook has a SATA hard drive installed and the XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX.
Aug 12, 2011 | HP Compaq 6720s Notebook
Hi, I have a HP NX6310 notebook with Win Xp Pro installed. I need to reformat it after it was heavily virused, and reinstall Win Xp but without the recovery disks I am rather helpless. The recovery...
You can't see any HDD's when trying to install because your BIOS system was set the IDE controller to an AHCI, you can set this to native IDE and windows XP setup will read a HDD's..
If you need set the IDE controller to AHCI you need Intel AHCI controller driver for your system, you can see it during installation process to press F6, you must use floppy diskette and put the driver onto it.
Another way to install AHCI driver is Integrate the driver into Windows Installation directory..See here for more details..
Aug 10, 2011 | HP Compaq nx6310 Notebook
HDD not recognized whe installing fresh Windows XP!
Hi...
If your HDD will not recognized during installation you need to check if your HDD is detected. Try to look at your BIOS if it is detected. IF the HDD will not detected you need to replace the cable, try to use the other slot of your SATA or IDE ports.
Regards
ICmanServer
Jul 31, 2009 | Dell Vostro 1400 Intel Core 2 Duo T5270...
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
Jan 27, 2009 | Compaq Presario C700T Notebook
Windows XP boots endless if SATA is set to AHCI
this is'nt so easy here an example solution:
Enabling SATA mode to AHCI after XP Install (applicable to most laptops, or systems) If you want to enable SATA mode as AHCI after installing Windows XP, then read on. It's a bit of a long read because of step-by-step instructions, but worth it.
I did this on on Acer Aspire 5315-2153, it seems like the basic strategy should work on other laptops or systems.
For whatever reason, you may have installed Windows XP on your new laptops with SATA Native Mode disabled in the BIOS. Once XP is installed, enabling it in the BIOS will result in a BSOD upon loading Windows because XP doesn't have the correct drivers.
I read that enabling SATA native mode will give you a slight performance inrease and slightly increased battery life, so it seems worthwhile to me smile.gif
Here's how I did it on a Acer Aspire 5315-2153 running Windows XP (32 Bit version):
- Download the Intel Matrix Storage Manager software from Intel (I think it's iata_enu.exe)or AHCI_Intel_v7.5.0.1017_XP.zip from Acer web site.
- Extract files from AHCI_Intel_v7.5.0.1017_XP.zip to e.g. C:\AHCI_Intel_v7_5_0_1017_XP files need: (you may delete the rest)
iaahci.cat
iaahci.inf
iastor.cat
iastor.inf
iastor.sys
TXTSSETUP.OEM
- Now go to Device Manager, under IDE ATA/ATAPI controllers you should
see: Intel 82801HEM/HBM SATA AHCI Storage Controller
- Right-Click on that and select Update Driver
- Say no to connecting to Windows Update to search, hit Next
- Select Install fro a list or specific location (Advanced), hit Next
- Select "Don't search. I will choose the driver to install", hit Next
- Select Have Disk
- Browse to C:\AHCI_Intel_v7_5_0_1017_XP and highlight the iastor.inf file, hit Open
- Select OK
- Now you should have a list of controllers, for the Acer 5315-2153 choose Intel 82801HEM/HBM SATA AHCI Storage Controller, hit Next
- You'll get warned that installing the device driver is not recommended, click Yes to continue installing
- Click Finish
- Click Yes to restart your computer
When your computer boots up, you need to hit F2 to enter the BIOS. Change SATA mode to AHCI, save changes and exit.
After you log into Windows, your computer will find the "new" hardware. Wait until you get the popup message to restart your computer, say Yes to restart one last time.
You may download also from Intel the RAID/AHCI Software - Intel® Matrix Storage Manager (iata70_enu.exe 5640KB) and install it in your system, it may fix in case you got the wrong Intel 82801 AHCI controller.
I give credit to Jamie Rybarczyk at HP Business Support Center forum for doing most of typing.
http://forum.notebookreview.com/showthread.php?t=186471
Jan 06, 2009 | Computers & Internet
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
