Balance CN6555 PC Notebook
Problem for Balance CN6555 PC Notebook
Computer not reading the hard drive
By nankeen64 on May 10, 2008
my computer is not detecting my hard drive. can i fix this problem without buying a new hard drive?
Comments:
May 11, 2008
- in the bios setup the computer is not detecting the primary IDE master
Best Solution
posted on May 12, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hello
if it is not detected in BIOS, you will need to replace harddrive in your system it is pretty easy and then you can upgrade your harddrive too, also after your replace your harddrive you might have recovery discs came with your system just put these discs in your system and reimage your harddrive.
Thankyou
Solution #2
posted on May 10, 2008
Helpful)
gagantib
Rank: Wiz
Rating: 83%, 33 votes
Hello
if your computer is not detecting harddrive, the best way is to replace the harddrive.
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
castatroy
Rank: Wiz
Rating: 83%, 106 votes
You will have to check whether you motherboard detects the harddrive first by logging on to the bios setup at the boot sector if it is showing the harddrive there then you might want to try downloading the latest bios update and installing it if all that does not work but the hard drive is showing on your bios setup them try re-installing the operating system here you must format the harddrive fully. If all these do not work then Im afraid you need to replace the harddrive.
Was this helpful?
Yes
No
Solution #4
posted on Aug 22, 2009
Very Helpful)
psuandme53
Rank: Apprentice
Rating: 100%, 1 votes
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Aug 19, 2009
Not Rated)
frederickmor
Rank: Apprentice
Rating: 0%, 0 votes
i bought another driver still not reading the hard drive what do i do next to fix it
Was this helpful?
Yes
No
Popular Solutions for Balance CN6555 PC Notebook
Questions and Unsolved Problems for Balance CN6555 PC Notebook
Do you recommend Balance CN6555 PC Notebook?
Answer
Answer
reset aspire one no display
Answer
why does the netbooks allow games to be played and how can i speed it up on the wi-fi.My netbook... (More)
Answer
how can I fix error code 720.I first got this while trying to connect to a wireless network. I get... (More)
Answer
I suspect it is the panel which got burnt, i have looked for a panel, can not find one here in... (More)
Answer
help---I am trying to type a spread sheet and it keeps scrEWinG me up...SEE
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Balance CN6555 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
