SOURCE: Dont have a problem but
christine93, Seller could give good serial # number fake watch. Contact Cartier on Bond street with serial # to make sure it was serviced and have them ship. EWorth it to know it is real. Many fakes are out there. If real cheap usually a fake.
SOURCE: is my cartier watch real or fake
You can distinguish real or fake.the real is heavy than the fake,fake is lighter.the color the real one is not to shine is dull,the fake is very shiney compare to real,the metal they use the real uses stainless,titanium and gold.The fake is nickel plate or zinc metal.the engraving the real is deep seated engraving,the fake is on the top only not so deep.I can't say your watch is real or fake,basing on serial number,the emitator can emitate the number.I gave you a tip how you know the real or fake.
SOURCE: Real or Fake
Real cartier santos watches are engraved on the back of the watch not etched on the back like a fake. Also the word cartier is engraved on the clasp of the bracelet. Do not but unless these two conditions are satisfied.
SOURCE: Fake or not
Generally you have to open the watch to see the movement but a lot of fakes are plain workmanship flaws.
A real Cartier will not be made from base metal. It will be made from stainless steel or precious metal.
A real Cartier will most likely be built with screws in the band instead of cotter pins.
When you pull the crown to set there will be no play in the set lever. In other words when you spin it, it will begin to turn the hand immediately and there will be a slight resistance. It will not feel loose.
As stated, the best way to tell is to look at the movement. Cartier uses a high grade Swiss movement most likely marked ETA.
Please dont forget to vote if you liked my answer
thanks
