Question about Fujitsu (G281065802)
Is it usual for the concentrator to take as long as 15 minutes to come up to normal oxygen when concentrator has been off for 30 minutes? Does the warning sound and lite also come on them?
  • Fujitsu Master
  • 1,606 Answers
That is not normal operation. You need to contact a service or support rep from Fujitsu or contact the company you purchased the unit from.
These should produce oxygen within a few seconds of being turned on and be up to full flow in well under a minute.That is going to vary by model but 15 minutes is too long.
Posted on Sep 01, 2010
How do high-concentration home teeth bleaching strips work?
high concentration home teeth bleaching strips use carbamide peroxide. A high concentration oxidizing agent is applied to the teeth to whiten them. These strips should fit well to keep in the bleaching gel and make certain it gets to each tooth evenly and fully. the strip will stay on for 15-30 minutes and then repeated twice more or else once a day for 2 weeks.
Apr 24, 2013 | Health & Beauty
After about 15 min the yellow light comes on but no alarm low oxy
Check that air intake and exhaust are not blocked. Check air intake filter, if dirty clean with mild dish detergent. Have filter completely dry before inatalling it and using the concentrator.
Apr 25, 2012 | DeVilbiss 525 Oxygen Concentrator
P-B Companion 590 Oxygen Concentrator is beeping. What should we check and fix to repair the unit? Can you provide a link to the manual or troubleshooting guide for this unit? Thank you for your...
When these units are beeping it indicates they are basically not running. So you first need to ensure who ever is using it has access to o2 if they require. There isn't much you can do to fix these at home. You can first try going over the following. Not really that helpful but might help you sort it out. If you can't spot anything obvious ie unplugged no power etc then first contact anyone local such as the medical supply place. That would get you the fastest repair or help. If you don't have one of those to call then don't be afraid to call the 1-800 number below and ask the company.
The local company or even your doctor might be able to help you get bottled O2 while your unit is getting fixed.
If there is an audible alarm -- concentrator is not running: • Is unit plugged into a working outlet? • Check circuit breaker -- Right side of unit, behind a small door on the Companion 590 and 429a -- Back of the unit on the Companion 492 -- Between the on/off switch and flow meter
If there is an audible alarm -- concentrator is running: • Concentrator cannot be fixed by consumer • Call 314.362.0720 or toll-free 800.456.9366
There is a visual alarm on the Companion 590 with oxygen concentration indicator: • Green Light -- Normal -- Oxygen concentrations are correct • Yellow Light -- Below Normal -- Oxygen concentrations have fallen below an acceptable level • Red Light -- Not Operating -- Oxygen is no longer being produced; audible alarm will sound and concentrator will shut down
Apr 04, 2011 | Health & Beauty
After 30 min low oxygen light come on
check the humudifier bottle and remove the bottle and check and again if it continues ,open teh cabined and chek for leakage near compressor end and and ther wil be ball kind white material will be there chek for crack and how old is the machine
Dec 22, 2010 | DeVilbiss 5 Liter Oxygen Concentrator with...
What are Eau De Toilette, Eau De Parfum, etc?
These terms refer to the strength of the fragrance, or more specifically, to how much high grade alcohol and/or water has been added to the fragrance oils. Parfum (generally the most concentrated form you can buy) has 15-25% perfume oil dissolved in alcohol. Any mixture with a lower proportion of oil to alcohol is an eau (water).
Eau Fraiche (Usually 3% or less perfume oil)
Eau de Cologne (2 - 5% perfume oil)
Eau de Toilette (4 - 10% perfume oil)
Eau de Parfum (8 - 15% perfume oil)
Soie de Parfum (15 - 18% perfume oil)
PARFUM or Perfume (15 - 25% - also sometimes referred to as extract or extrait)
Perfume oil (15-30% perfume oil in an oil rather than alcohol base)
You may also see the term Parfum de Toilette. Most companies use this term to describe a concentration that is either the same as Eau De Parfum, or between Eau De Parfum and Parfum. Other companies use the term to describe an Eau De Toilette concentration.
To further confuse matters, some companies use different notes, or different proportions of notes, in the different forms of fragrance they offer. In addition, some companies reserve costly fragrance oils for their parfum, and use synthetic substitutes in lighter concentrations.
Nov 23, 2010 | Health & Beauty
Other than not passing or producing oxygen flow is it possible for a concentrator to produce carbon monoxides or other gasses? After looking at and reading the information provided on your site it seems...
You are correct. This concentrator is oxygen specific. Therefore it only concentrates the oxygen, not other gasses. Joe
ps please rate my answer as very helpful.. thanks
Mar 29, 2010 | DeVilbiss 5 Liter Oxygen Concentrator with...
I need instructions for DeVilbiss 5 ltr. Oxy Concentrator
I believe I can, Please contact me at
hollyg916@yahoo.com In subject put oxygen. will be looking to hear from you.
May 25, 2009 | DeVilbiss 5 Liter Oxygen Concentrator with...
Screen tuns black after 15 seconds and comes back after about 15 minuts
The solder joints on the vertical output IC have cracked. This is a very common problem on those sets.
Nov 14, 2006 | Panasonic CT-27G34 27" TV
Fujitsu (G281065802) Logo
160 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
