Question about HP Compaq nc6000 Notebook
Function key problem with compaq nx6120
Whenever i press Function+F3, it will go to standby and Function+F4 for external display.
But its not working now.
Kindly help.
  • 47 Answers
-Click on run from start menu
-Type gpedit.msc
-User Configuration
-Administrative templates\Windows Components\Windows Explorer
-Double click "Turn off Windows +X hotkeys"
- Try the different settings (i.e. not configured, disabled, etc) to see if any of these solve the problem
Posted on May 10, 2008
Connect external monitor to laptop - how do you do this - ie which keys to press to convert it over to the external screen once connected?
Almost all laptops, especially those made within the last few years, have the ability to connect an external display, such as a CRT monitor, flat panel display, or Projector, and have the display sent to that device instead of to the laptop display.
Connect the monitor, flat panel, or projector to the laptop's 15-pin video connection on the back of the computer as shown to the right. Once connected, your laptop may automatically switch to the new external display or you may be required to press a sequence of keys in order to switch from the laptop to the external display.
The key sequence can vary depending on laptop, however is often either: Fn + F3, F4, F5, F8, or F9. This means if you were fore example to press and hold Fn + F3 at the same time it'd switch between your laptop display to your external display. The function key will often be labeled as CRT/LCD or have a picture of a monitor on the key or close to the key. Unfortunately, the keys pressed to switch displays is dependent on the model and manufacturer of the laptop. If none of the above key sequences work, consult your laptop documentation or consult your laptop manufacturer.
Some laptops also have the ability to have the display on both the laptop and external display or a single display at a time. Laptops with this ability can switch between these modes by continuing to press the same function keys until in the mode the user wants
If you are having doubts you can get in touch with a technician
you can get in touch with them through the website
www.thebestpcdoctor.com
Toll Free: 877 407 9229
Oct 03, 2011 | Toshiba Satellite Pro L300 Notebook
I have another vga monitor connected to travelmate 2300. what buttons do i press to make it work?
Jun 18, 2011 | Acer TravelMate 2300 Notebook
Connect laptop to external lcd monitor
This laptop has a blue VGA port. Plug your monitor into it. You might have to adjust the BIOS to recognize the external device.
Once connected, your laptop may automatically switch to the new external display or you may be required to press a sequence of keys in order to switch from the laptop to the external display. The key sequence can vary depending on laptop, however is often either: Fn + F3, F4, F5,F8, or F9. This means if you were fore example to press and hold Fn + F3 at the same time it'd switch between your laptop display to your external display. The function key will often be labeled as CRT/LCD and/or have a picture of a monitor on the key or close to the key. Unfortunately, the keys pressed to switch displays is dependent on the model and manufacturer of the laptop. If none of the above key sequences work, consult your laptop documentation or consult your laptop manufacturer.
Some laptops also have the ability to have the display on both the laptop and external display and/or one or the other at a single time. Laptops with this ability can switch between these modes by continuing to press the same function keys until in the mode the user wants.
Aug 05, 2010 | Toshiba Satellite A300-ST6511 Notebook
VAIO VGN-Z520N/B 13.1" Laptop : where is the volume control on sony vaio laptop...
You can use the Fn+F3/F4 Function Keys to control the volume.
To increase the Volume, press Fn+F4 and then press Up or Right, or Keep pressig Fn+F4.
To decrease the volume, press Fn+F3 and then press Down or left, or Keep pressing Fn+F3.
Hope this helps..
May 13, 2010 | Sony VAIO VGN-Z520N/B Laptop
I have just plug in a monitor to my laptop and I don't know what button to press to make the monitor work? Can you help!
Here is the user manual: http://office.manualsonline.com/manuals/mfg/compaq/presario_700.html
Try Fn (function key) and F5 or F6 key, it will let you toggle between external monitor only or both external and internal. Just read the manual.
Mar 24, 2010 | Compaq Presario 700 470024-192 Notebook
I can not work out how to turn the wireless conection on.advent 7070.what keys do i use
To enable the Wireless LAN Fn + F2
usually the wifi function key has the universal antenna symbol with radio waves emanating from it.
The manual says the other hotkeys are:
Fn + F2 - Wireless LAN
Fn + F3 - Standby
Fn + F4 - External display
Fn + F7 - Reduce brightness
Fn + F8 - Increase brightness
Fn + F9 - Play / pause media
Fn + F10 - Stop media
Fn + F11 - Media previous chapter
Fn + F12 - Media Next Chapter
Fn + scroll - Scroll Lock
Jan 14, 2010 | Advent Netbook
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
Oct 11, 2008 | HP Pavilion dv1000 Notebook
External monitor for amilo pro v2030
hi
when the external monitor is connected hold down the function key " f n " ( which is located 2nd on left of lowest row ) and then press either the F4 or F5 function keys on top line....the one that has a small icon like a rectangle or tv screen on it ....it has usually 3 toggle positions so if it dosent work first time then just press the same key again (still holding fn key) until it allows the monitor to get the signal.....if F4 dosent work then go thru the same sequence with F5 but depending on the laptop model it could be any one ...F3/F4/F5/F6 the usual suspects....
hope this helps
Jan 04, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
HP Compaq nc6000 Notebook Logo
149 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
