Question about Kenmore HE2 Plus Front Load Washer
Kenmore elite he4t makes a sound like a card in the spokes of a bike when spinning. Everything else seems to work. It was just moved cross country.
  • Kenmore Master
  • 2,694 Answers
The spider gear is bad,you can take the bottom panel off to see if the shocks or one of the shocks are broke but if it's happening in the spin cycle it's the spider gear.i hate to tell you this but it would be cheaper to change out the washer,the gear is like 500 bucks just for the part and you have to pull the hole washer apart to get at it and split the tub and change out the back part of it,this happens mostly from using to much detergent,it eats at the spider gear and it crumbles like acid is on it,everybody reads the back of the bottle but those measurements are for top load washers,the front loaders use less water and very little detergent and it should be H.E. detergent,it has less suds in it.let me know how you make out,don't call anyone in to check it,isee this all the time,save your money for a house call.good luck
Posted on Sep 01, 2010
Self cleaning button sequence want start
you need to see in the bottom of your washer or take the back panel and some of this washers have a reset button, try due that, make sure is unpluged while you due this, clean all the contacts inside and check all the wires make sure they okay
Oct 17, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
My Kenmore Elite He4t front load washer is making a terrible noise when it starts spinning the clothes. What could be wrong?
Sounds like the rear bearing. If you hear the noise when you manually spin the drum or if the drum has any movement when you lift up on it then you need major repairs
Feb 27, 2011 | Kenmore Elite 45986 Front Load Washer
My back wheel is making a ticking noise when i stand up and pedal. I lubricated the cross points of the spokes and it is still making the noise. I took the tire and tube off but i'm wondering how to get to...
You may have a loose spoke or two. A rubber liner usually covers the spoke heads. If you do your own repairs, invest in a spoke tension gauge and the tool to adjust the spokes.
Jul 28, 2017 | Mavic Ksyrium Elite Wheelset
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4T won't stop on the Spin Cycle. Stays
Replaced the relays with the 16Amp rated ones from Digitel.
Aug 15, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Clicking sound.....
must likely something in between drum & basket or rear bearing going bad.call sears ask for service smart agreement it will cover rear shell with bearing &basket in warranty
Nov 13, 2008 | Kenmore Elite 45986 Front Load Washer
F Code for the Kenmore Elite he4t Front Load Washer (3 years old)
Hi! ricksmith
What is the first three digits of the model number.
The he4t I have reference to does not have a "F" code error. Most of the codes are two digit, PF, F1 to F9 etc.
You could try: Pressing Pause/Cancel two times to clear code. As well as unplug for 20 seconds. Do you have power fluctuations in your area.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore HE2 Plus Front Load Washer Logo
101 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
