Question about Traulsen Refrigerators
Stock in defrost - Traulsen Refrigerators
  • Traulsen Master
  • 43,501 Answers
The defrost timer has gone bad....Find the timer and manual advance the center knob till the unit comes out of defrost.... the arrow will show which direction to turn the knob...Then you will need to replace that timer...it is not hard to replace just mark all the wires and kill the power before attempting to replace it....
Your timer will probably look something like this one....just match up the voltage and everything else...
heatman101
Posted on Sep 01, 2010
I replace ADC 12566102 still defrosting every 4 hrs and stock the temp to 20 freezer won't reach to zero to make ice
If self defrost mechanism is working properly then the issue has to lie with a faulty thermostat that is shutting down the compressor prematurely or low refrigerant charge.
Ice maker will not work until freezer temps go below 10 degrees.
Feb 21, 2017 | Refrigerators
Freezer temperature alarm light on and freezer is melting
HI,CHECK THE COMPRESSOR AND RELAY,TIMER PROBABLY THE UNIT TIMER OR DEFROST CONTRL IS STOCKED ON THE DEFROST CYCLE.UNPLUGGED FROM POWER FOR 5MIN AND THEN POWER BACK SEE IF ADV HELP..
Jul 05, 2011 | Kenmore Freezers
Freezer not defrosting
try to rotate manually defrost timer possible stock up or the thermo disc defective replace it or the dfrost heater busted need technician for replacing this parts conduct observation after.
Mar 04, 2011 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Freezer is cold but fridge is hot.is there a timer to defroze timer can it be faulty.need your help from ram.
try to check your evaporator fan if working. replace it if defective try it defrost manually then observe or check defrost timer and defrost heater rotate deforst tmer by your hand possible stock up thes thing you do if it is a build up ice in the freezer.
Feb 27, 2011 | Ariston Technologies Refrigerators
Whirlpool refrigerator type 2255A The problem I
check your defrost timer manually rotate it possible stock up or replace if damage check the resistance of your defrost heater if good the freezing is normal try to adjust it to the next level of adjustment then conduct observation. check also the thermodisc it is connected to sense the ice vulging of your unit that trigger the defrost heater and defrost timer observe unit.
Feb 19, 2011 | Whirlpool Freezers
1984 panasonic fridge defrost timer
That panasonic model number doesn't come up in my parts catalog.But defrost timers are pretty generic.Most refers in that era use the same timer.Locate the timer and remove it.Take it to any appliance parts store and they can surely match it up with a universal timer that they have in stock.Cost is less than 25.00.
Mar 18, 2010 | Refrigerators
I have a Whirlpool model ET8CHMXQ0 and the drain freezes upp all the time the defrost timer,defrost thermastat and heater are working any ideasI know of two the same model with the same problem.
most of these models have this problem . when in defrost cycle the heat should control this . but is does not .. I USE A AFTER MARKET HEATER FROM SUPCO (electric and easy to install / justsets in drain and has probs. . any parts dist should have then in stock ( not sears . ) hope this helped mm pls leave feed back .
Dec 07, 2009 | Dryers
Westinghouse Fridge problem
-Try defrosting the unit. (force defrost)
- Check air vent if air is present.
- Check if the unit is not overloaded with stocks or air vent block with stocks.
- If no air is present in vents then check your blower inside if operating.
Feb 29, 2008 | Refrigerators
Refrigerators Logo
155 people viewed this question
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
