Question about Vizio P50HDTV10A 50 in. Plasma HDTV
My tv turned off like if someone used the remote and it never went back on it is as if no electricity is going thrugh the set not even the stand by button lights up i have had my sett for about 3 yrs.
    Genius:
  • 1,622 Answers
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Thanks and take care...
Posted on Sep 01, 2010
Ibought a MagnavoxFlatscreen Model#26MF231D/37 aman wasActually usingbuttons oftop ofthe tv2 watchtapes 2make thetvwork Iwant 2know how2 getit 2autoprogram so I can use my cable tvremote with thisTV
There are a lot of things a cable TV remote cannot do even if you have the correct code to turn on and ogg the TV. Try going here to find an original replacement remote control TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 10, 2016 | Televison & Video
Panasonic TX-L42S10B has power but won't turn on
ok, this may be a silly question but when you turn it on and it starts flashing red, have you tried pressing the stand-by button on the remote. if a tv has been put on stand-by by the remote, and is then switched off by the set, when the set is turned back on it is still in stand-by mode and you need to press the stand-by button on the remote.
other than that I don't know.
Nov 08, 2013 | Panasonic TXL42S10B 42 in HDTVReady TV
What if the tv is off and the red stand by light is not on what does that mean
The red "stand by" light shows power is getting to the TV. If it is off, you may have no house power being connected. If you can get the red light to come on but your TV still does not turn on the power supply may have failed
Apr 04, 2013 | Sylvania Televison & Video
Wont power on
some tv's always have standby light on, even iff you turn off by tv button. solution 1: with light on, press a number on remote. solution 2: with light on press stand-by button on remote. solution 3: with light on push the 'on' button on the tv set. solution 4: unplug tv set, wait a few seconds then plug back in, if no light then turn on tv using button on the set, and then channel number.
Jun 25, 2012 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
My Element 40" Tv is stuck in stand by how do I
hi have you changed the batteries in the remote, if the remote is ok there's a fault with the tv, could be a swollen capacitors shorted diode or poor solder joint,or a bad mainboard , thanks
shaun
Mar 08, 2017 | Element ELCHW402 40 in. LCD HDTV
I have a Mitsubishi 73"
i would suspect your control buttons on your front panel on the set have become shorted. specifically the volume buttom down. This is freezing you control functions. like someone is holding the volume down button all the time. or intermitantly. this cuircit board is on front of the set. I have seen this problem a few times at the shop. The common repair is to replace that button assembly cuircit board. I believe the last time it cost the customer around 85 dollars, but like all things depends on the part and the technician that puts it in.
Apr 21, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
BOUGHT A USED SHARP TV WITH THE POWER BUTTON MISSING .IT USED TO COME ON WITH REMOTE BUT EVEN WITH FRESH BATTERIES IN THE REMOTE IT WILL NOT TURN ON THE TV. DO YOU THINK THE REMOTE WENT BAD?
To power on the tv with your remote, the tv must be in stand-by. You should look if the tv is in stand by. If it is not, you should use a pen to power on the tv. (press where the button was)
hope it helps :)
Apr 22, 2010 | Sharp 25R-S100 25" TV
Emerson remote control
It sounds like you loaded a wrong code to the TV. Though I don't know how. You should have been loading the TV's code to the remote. but if nether remote will work then something got loaded to the TV. check your TV's owners manual. There should be a way to bring everything back to default. Usually by pressing a series of buttons on the menu and turning on the tv. I wouldn't know the set of buttons as every tv is different. But it should be in the owners manual or on the web site. Reseting the tv to default should cure the issue. Sony will help you but they will charge you for the call. If you cannot find the information in the owners manual go to sony's web site and check the FAQ section to see if someone else has had this problem. Sony is usually fairly good with information on the web. You should be able to find what you need to do to take the TV back to default. BEWARE THOUGH! any information you programmed to the tv will be lost when you do this. You will have to reprogram it. (TV channels etc...)
Jan 24, 2008 | Dryers
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
