Question about Frigidaire Washing Machines
I want to winterize a washing machine in a Maine cottage. How do I get the water out of the mixing valve..? I thought I had completed the job,but,the mixing valve burst during the winter las tyear.. thanks for you help...
  • dchamb4312 Sep 04, 2010
    Not a good solution..I indicated I wanted to know how to remove water from the valve..I turn the
    electricity OFF during the winter..Thanks Dave Chambers dchamb4312@verizon.net
    President:
  • 3,773 Answers
The best way to winterize the mixer valve is to purchase a
warming strip and wrap it around or under the valve.
Some refrigerators have these strips inserted into the drain
of the freezer to keep it the drain from freezing.
They use a negligble amt of electricity and they will plug into the
socket behind the washer.
You can probably find one of these at your local appliance parts
store. But you have to ask for a drain warming strip.
also i think the major lumber yards will have these warming strips.(Lowes,Home Depot,etc.)
Thanks for using me to help. I am happy to assist.
Let me know if you need any other info.
imufo
imufo2@sbcglobal.net
Posted on Sep 02, 2010
  • Leo Ponder
    Leo Ponder Sep 04, 2010
    Sorry, I didn't know that. The only way I could advise is to remove the mixer valve.
    Or make sure the hoses are removed so there is no pressure .
    One sure way would be to take off the hoses and blow compressed air into the va
    lve openings.
    You also may lay it down on its back and let the water drip out.
    Hope this helps.
How to adjust Banner M580 Series faucet to provide a better hot/cold balance?
Could be a defective mixing valve or blockage in the cold water input line to the valve
Jul 26, 2016 | Banner Faucets Pro Series M580 Single...
Water collecting in wash drum when not operating
You are correct. One of the solenoids on the water valve is not shutting completely and will need to be replaced before it sticks wide open and cause a flood. Here is the part to order. To replace the valve, remove the screws on the top panel, slide it back and lift it off. There you will have access to the valve replacement.
Nov 05, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Water on floor; problem was occassional, but today was a ''flow''. Coming from left-side back corner and noticable on hot water wash cycle; swithced to warm cycle, went to drip. Suspect whatever the mixing...
Upon further investigation (opening up the front panel & top) could tell it was the injector valve (between the mixing valve and tub inlet). You would think after 21-years they would have designed a more robust solution!! Quick trip to the parts store, back together and working fine.
Thanks for letting me vent.
Mar 31, 2010 | Maytag Washing Machines
How dow I winterize LG front load washer?
very simple
get a towel
take off the back wall
remove one of the pump hoses
id remove the front one since the back has a check valve
let the machine
drain and you should be fine
you can eith recoonect then or when you get back
Oct 07, 2009 | LG WM-2077C Front Load Washer
Water is pooling in the wash tub even after the cycle has completed. the next day, the tub is full of water and leaking out the front
Your Mixing Valve (water valve) is not shutting properly.
Replace it to solve your problem.
Thanks for using FixYa!!
Jul 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer fills with water when the machine is not running
Either the hot or cold water valve is not closing completely. In either case, the mixing valve assembly will require replacing.
Feb 04, 2009 | Kenmore 42924
Proceedure to winterize washer
HI thanks for your question. the easiest way is to. pour plumbers anti freeze in it 1 gallon should do it . thanks the appliance doc. oh, start it up in the wash cycle for a few minutes, to cycle the water.
Oct 01, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
The water supply to my my 2004 Maytag Neptune TL top loader will randomally not shut off, casuing the washing machine to file up to the top overflow and flood my first floor. At first it was thought that...
You have several possibles problems
The pressure switch could be faulty or the tube that runs from the pressure switch down to the accumualtor could have a cut or tear in it. solution replace hose.
or The mixing valve could be hanging open also with a piece of debris. solution replace mixing valve
For now turn the water when your not using your machine.
May 19, 2008 | Washing Machines
Washing Machines Logo
176 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
