Question about Goodman Heating & Cooling
2 and half straight air unit freezing up after several hours system has o61 piston should it be something diffrent
  • Goodman Master
  • 43,501 Answers
No, the system is undercharged... add more freon to the system to raise the evaporator temp. so it does not freeze...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
heatman101
Posted on Sep 01, 2010
Hi, I have a Samsung Blue Ray home cinema system. When playing a Blue Ray disk it freezes after about an hour and a half. DVD's seem to play no problem. Have tried a cleaning disk but has not
Hi, if your sure it stops in the same time on any disc then i would assume there is something stopping the laser from moving forward.
If your confident opening it things may be obvious, KEEP HANDS AWAY FROM THE MAINS COMING IN.
The laser runs on two metal bars but all the gears are plastic up to the motor. The motor does'nt spin but turns in small movements as the laser reads in front, sometimes the teeth on the gears get clogged up. Let me know how you get on.
Jan 05, 2015 | Samsung Televison & Video
Gas Gauge fluctuates, Overheating even with enough antifreeze & Heater blowing freezing cold air.
GAS GAGE IS EITHER A BAD SENDING UNIT OR "SLOSH MODULE" IF A FORD. HEAT ISSUE IS A VACUUM LOCK IN THE COOLING SYSTEM AND NOT ALLOWING THE AIR TO ESCAPE AND NO WATER TO CIRCULATE.CHECK FOR LEAKS ,THE THERMOSTAT,AND WATER PUMP FOR PROPER CIRCULATION
Oct 09, 2012 | 1997 Mercury Mountaineer
After all the soldering is complete from the a coil to the condenser , do i have to add any coolant to the unit?
Is this an a/c system added to your furnace if so there is other steps needed before the freon , it needs a vacum pump put on it for several hours to clean out the lines (longer if you didnt run nitrogen while soldering) ect. but to answer your question the condensors come precharged for lines between 20-30 ft. they are all diffrent so you have to look in your install guide to verify. Hope it helps
May 31, 2011 | Goodman Heating & Cooling
I have Carrier Heat pump model # 25HBA. It was installed 3 years ago. I have had problems with it several times. This time, it is freezing up on the outside unit. My electric bills have sky rocketed. What...
The cooling coils are freezing because the gas (coolant) in the system may need replenishing or a small leak in the system. Something you can check yourself, is whether or not the foam insulation on the refrigerant tubing coming out of the unit is still intact. If not, that tubing is probably freezing too.
The other possibilities will need to be check by a qualified service technician.
Feb 10, 2011 | Carrier Heating & Cooling
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
The beverages in my True refrigerator are frozen
Definitely a thermostat problem. Make sure that it is set on #3, make sure you have something in the box to provide a constant load (if you are worried about product freezing just put several gallons containers of water in there), set a thermometer on a shelf and let it run for several hours. Temperature should run 35-40f If it still freezes I recommend changing the thermostat. Not the easiest job on a True but the only real option. If it is too warm then raise the setting to #4 and run for several hours more and double check the temperature. It is normal for these box temperatures to "swing" quite a bit especially if empty. The thermostat actually senses coil temperature and not unit air temperature. Typically it cycles off when the coil reaches around 14f and then back on when the coil gets to around 38-40f.
Jul 01, 2009 | True GDM-23FC-RF Refrigerator Commercial
Right out of the Box the thing freezes up right away on the bottom shuts off from the cooling cycle till it melts and starts up again. Does it over and over again. It is used in my bedroom that is 22x24. I...
Maybe you forgot to unwrap something inside the a/c unit. Check that hot air is coming from the other side(outside) and cold air(with force)is coming in. If there is no good flow, the cooling coils will freeze.
Jun 24, 2009 | Goldstar KG6000R Window Air Conditioner
WHAT OIL IS RECOMENDED FOR IR315 STRAIGHT LINE AIR SANDER
I just use my regular air tool oil on mine, have several of these IR longboards. Rick
Mar 20, 2009 | Ingersoll Rand HD Air Twin Piston...
Garmin 2610 freezes-up
CHECK THIS OUT IF SCREEN CLEANING DOESN'T WORK.
Regarding the screen jitter, believe it or not, the infrared port is causing the issue. If you disable it through settings inside the unit your issues will go away. The sun basically destroys the infrared sensor and the unit "thinks" a button on the remote is getting clicked continuously.
Nov 03, 2007 | Garmin StreetPilot 2610 GPS Receiver
Heating & Cooling Logo
47 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
