Question about Kitchen Ranges
One of the spark ingnitors is not sparking, how can this be rectified?
  • Kitchen Ranges Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Sep 01, 2010
No spark on ignition coil on my bajaj wind 125 my cdi , rectifier and stator are new.
Put a test lamp and connect with an earth then crank the engine the bulb should flash for a moment if the coil is ok ...
OR, there is a another simple method just take out the spark plug connector and place is at a very near to the spark plug end and then crank the engine if every thing is fine ( OK condition) then one can see the spark in between the the spark plug lead and the HT cable.
Dec 28, 2014 | Bajaj Wind 125 Motorcycles
99 bear tracker
ok did you check for a good engine ground
Jun 09, 2014 | ATVs
Triton 10 L wont light up has inginiton but not getting gas
There is something that must be blocking the pipe for the gas to flow check the pipe
Feb 12, 2014 | Camp Chef Triton 10L Portable Water Heater
50cc apache quad spark problems
Could be the CDI. Check the stator and pickup coil specs with a multimeter first.
Nov 17, 2013 | ATVs
No spark from the spark plug
start simple, check fuses if okay check solenoid to see if its feeding system power. coil is bad or rectifier is bad check for spark from coil if none get a new one
Mar 23, 2011 | Yamaha TT-R 125 E Motorcycles
I have changed my stator and cdi box on a 1999 polaris xplorer 400 i have one spark at the begin of starting but its not contounious how do i test the regulator rectifier
According to my polaris manual, is says'' The regulator / rectifier is tested by process of elimination ( when all other possable causesof chargingsystem failurehave been checkedand eliminated, the rectifier is defective). I had to replace my stator and then had a simular problem as you have and it was that the ignition pulse coil wasn't properly guaged ( sometimes the metal retainer will allow slight movement) You might want to also check the coil resistance 0.3 to 0.5 ohms the coil secondary resistance spark plug cap installed 11,300 ohms spark plug cap removed6300 ohms. Hope this helps out. Good luck
Mar 26, 2010 | Polaris ATV
Dryer is not getting hot
These dryers have an auto spark ingnitor just like a gas stove. They do go bad and need replacement. Upon turning on your dryer, you should hear the ignitor click at least once to ignite the burner. If not I would check the continuity to that ignitor first
Jan 22, 2010 | Fisher and Paykel DE27CW1 Electric Dryer
There is a good spark good compression clean fuel but it wont start
Hi there... Here is some food for thought.... If you have good spark, good fuel and compression , check the rectifier, If this is faulty you will get the same symptom's  The rectifier is generally located under the seat and is one of the first things coming off the battery,  ITs primary function is to control the power coming from the battery to supply a steady and cleaner power supply to all electronic components so.. you may have spark but your timing will be either lagged or premature before the spark can ignite it. ITs generally not an expensive part and is usually over looked in most cases like this...
May 14, 2009 | 2004 Honda CRF 250 R
Ge gas kitchen range 2 igniters work and 2 don't
Lift top upward & look under, you'll probably see small wire(s) running to ingnitors, see if perhaps wire fell off side not working.
Dec 10, 2008 | GE Profile Spectra JGBP85 Gas Kitchen...
Spark
I'm not gettin any spark it has a new rector firer any ideas ?need to check the coils first (rectifier ) is a voltage limiter and would not stop it from sparking.,,
Nov 10, 2008 | 2000 Cagiva River 500
Kitchen Ranges Logo
50 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
