Question about Maytag Washing Machines
Maytag washer sav5701aww the agitator in my machine seems to be composed of a large inverted cone / agitator with a stem, and on the stem is a small spiral shaped agitator. Is the small spiral agitator supposed to float on the shaft / stem or should it be fixed to the shaft? I don't know if it's broken. And if is can it be repaired?
5 Suggested Answers
Lumpy816
  • 246 Answers
SOURCE: Loose Agitator
Usually, there is a bolt that holds the agitator on. If you remove the cap off the center of the agitator, you should find a bolt underneath that you can tighten back down. Adding a little thread lock to the bolt wont hurt.
Posted on Jul 11, 2008
  • 103 Answers
SOURCE: Maytag Washer noisy & leaks lots of water from bottom of machine
the drum bearing are damaged due to water leak from seal inside the drum. that's why water on the floor. silicone paste mo use as it has other major problem.
Posted on Nov 02, 2009
SOURCE: GE top loading washer Washer wwse5200- Agititation?
It is a cast aluminum peice below the agitaror that costs about $50.00 from GE.
Posted on Nov 22, 2009
jan mczeal
  • 632 Answers
SOURCE: agitator wobbling from the stem. it comes right
Those are the agitator dog ears. They have teeth that grip and turn the top agitator during the wash cycle. It must be replaced when damaged or worn.
  1. Unplug the washer.
  2. Remove the fabric softener dispenser by pulling it off the agitator top.
  3. Look for the prying location on the agitator cap and insert a flat blade screwdriver between the agitator cap and the agitator then pry the cap off.
  4. Use a socket wrench, usually 7/16", with extension to remove the stud and seal holding the agitator to the shaft.
  5. Pull the top agitator from the bottom agitator.
  6. Pull the cam that holds the agitator dog ears from the top agitator.
  7. Lay the cam on its top and install the agitator dog ears on their slots.
  8. Hold the cam on one hand and the top agitator on the other.
  9. Slide the cam up into the top agitator and turn it over so that the agitator dog ears do not fall off.
  10. Reinstall the top agitator into the bottom agitator.
  11. Reinstall the agitator assembly into the shaft.
Posted on Jan 12, 2010
Maytag Dependable care, LAT9416AAE transmission shaft agitates but agitator does not
then the agitator cone inside the machine has a stripped spleen
not hard too do with castings
you need to demount the internal cone and check its spleen connection is solid
its much like the half shaft in a car
Feb 08, 2015 | Maytag Washing Machines
My Maytag A9700 is leaking from the bottom of the outer tub. I have changed both the tub bearing and the stem seal but it is still leaking - even more than before I started. My question is whether I
If the boot seal was properly seated onto the outer tub lip, then you should focus on the water seal (#39 in the graphic - it should have come with the mounting stem kit) as the source of the leak. Extra care must be used when installing this over the agitator drive shaft - some recommend adding a lubricant (Maytag center seal grease works well) to the shaft before sliding the mounting stem (and water seal) down onto the agitator shaft. Also, check the two sealing surfaces where the top of the boot seal (#40) meets the bottom of the mounting stem (#30). Look for cracks, chips or any bits of debris. Anything that keeps those two surfaces from meeting perfectly will cause a leak. These repairs should go fairly smoothly, but leaking water seals and chipped boot seals can cause problems.
Dec 06, 2014 | Maytag Washing Machines
My maytag washer model pav2300aww will not spin even though it agitates and drain but when it comes to the spin cycle it just kind of hums I looked at the bottom of the washer while it was in spin cycle...
Possible the revolution takes place on the top end of the pulley and belt but the centre stem of the agitator is not moving or it is slipping. It can be due to friction in the stem of the agitator due to clogging of dirt and the best option is to remove and clean the agitator.
Dec 11, 2012 | Washing Machines
How do you take out the agitator?
I don't know this machine but if you have removed all the fasteners, you might try this. I found that putting a mountain bike inner tube under the agitator around the edge with only the stem exposed and pumping it up with a hand pump can pop off the agitator from an old Maytag wringer washer. Maybe this will help you.
Mar 15, 2010 | Maytag PAV2300 Top Load Washer
Nov 02, 2009 | Maytag Washing Machines
Agitator has large break in it would like to take
Take the cap off with a screwdriver, then remove the bolt and pull the agitator out. Replace with one exactly like it.
Jul 14, 2009 | Maytag MAV6200 Top Load Washer
Maytag washer will not agitate.
needs transmisson replaced cheaper to buy new machine
May 20, 2009 | Maytag LAT3600A Top Load Washer
Water leak
If the main seal is leaking there will typically be a splash line around the inside of your washer cabinet. There is a special wrench available for removing the large nut that holds the inner basket in. This nut is aluminum and can be removed with a chissel if it is stuck. remove the inner basket and you will see cone shaped "NUT" that is covered in cork. There is a torx screw on the side of the cone shaped piece. once the screw is removed then the cone shaped nut can be removed using the special wrench and brute force.
Mar 10, 2007 | Maytag Legacy Series Top Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
