Question about Dewalt Saws
Saw is making aloud noise & its locking up - Dewalt Saws
  • 395 Answers
Sounds like all the bearings in the Saw are worn out and need replacing straight away before any more damage occurs.
Posted on Sep 02, 2010
My sym symply 2 125 broke down this morning.it was making aloud ticking noise and then completely shut down.the electric start just makes a click now when pressed and the kick start is jammed. Only the...
That loud clicking was most likely a rod bearing going out. The bike quit and locked up as a result. This is serious and expansive. Sorry
May 07, 2014 | Cars & Trucks
My washer will not spin or agitate, but will fill & drain
with it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Feb 08, 2014 | Washing Machines
My whirlpool refrigerator is making a noise
check the evaporator fan in the freezer and also the one near the compressor, one my be shot and squeeling
Feb 05, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
It making aloud noise when spinning dry
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
FOX 254 MM TABLE SAW E36-529 PRESS START SAW STARTS THEN BLOWS TRIP
Making sure the saw is unplugged ( not just turned off ) and using a pair of heavy gloves, grasp the saw blade carefully and see if it turns freely. If not then dis-connect the drive belt from the saw and try again. If he saw turns easily now and make no grinding noises then it appears your trouble is elsewhere. While the belt is dis-connected try to turn the motor my hand. It should turn smoothly but with a little resistance. If it turns ok then we must look elsewhere again.
Look at the specifications plate on the saw to determine how many amps the saw requires to run and then check the rating of the circuit breaker that trips when you turn on the saw. If the saw requires 15 amps to run and is on a 15 amp circuit then it needs to be relocated to another outlet, preferably one with a 20 or 25 amp breaker.
Mar 13, 2011 | Saws
My front loading washer makes aloud noise and shakes terrible when it spins at mediun or high speed. model ifw7200tw
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Nov 26, 2010 | Washing Machines
Auto door lock on driverside is making aloud noise and will not o
sounds like a striped gear to me replace the power lock
Jan 23, 2010 | 2000 Chrysler LHS
Peugeot 205 diesel - grinding noise on full lock.
may be the slip joint in the steering column is slipping in a rotational way stick your head under the dash and turn the wheel and watch the slip joint in the column if the lower part stops but the top part keeps moving get a new/ second hand stearing collum
Oct 02, 2009 | 2001 Daewoo Nubira
My sw 15 sub woofer is making aloud humming noise ithink it is oprably the fan
Most likely, you could feel the fan if it was that, but it could also be the the cord that connects the Sub to the main console, much like guitar feedback on an amp
Aug 18, 2009 | AudioSource SW-15 Subwoofer
Saws Logo
148 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
