Question about D-Link DGL-4100 Router (DGL4100)
I have a DGL-4100 Router and a switch and there is one site I am having repeated problems using and the program they offer. is the site and sometimes I can turn on the program and it logs me in fine so I can use it, other times it keeps telling me that a firewall or networking issue is blocking it. I even have this problem when trying to access there web page, just will not load it even though I can go anywhere else on the net I want at that time. I asked the site if they are having problems and they said not all at and no one else in the forums are reporting a log in problem but me so I am stumped. This program has to authenticate you to make sure you have a valid copy when you load it and sometimes it will load and other times it will not. I tried various things with the Dlink but I can not get it to make this odd problem go away. I mean I should at least be able to reach their website even if the program will not load and they say they are always up. So something is blocking somewhere and I can not find it. Even called the ISP Comcast and they said nothing on their end can cause one website not to load. So help would be appreciated
  • 19 Answers
SOURCE: error 503 service unavailable
theres something wrong with your router; try to check if the router is working.
Posted on Feb 04, 2008
SOURCE: Site is block by router?
my problem has been must consult the OpenDNS site to fix yours....just click here to go to the site....enjoy your friendster surfing...PLS. SHARE YOUR KNOWLEDGE.....:D
Posted on May 17, 2008
  • 186 Answers
SOURCE: Dual Router Configuration
Plug the second router into the lan not the wan and it will act as a switch instead of a router
Posted on Oct 02, 2008
SOURCE: Unable to access DLink WBR 2310 Configuration page
Reset the router first, press the reset pinhole on the back for 10 seconds using a paper clip, don't press it too much or it will mess up the settings of the router. then try to access again the configuration page.
Posted on Feb 10, 2009
  • 611 Answers
SOURCE: wireless dlink dir-655 router not working. I
just off the firewall or proxy server or anti virus for configuration time and just connect the cable to the LAN port of the router and other end to the PC then try to open the configuration page of the router go to the explorer or Mozilla there you have to type default ip in the addresss bar or try both which is the open then go it after that in cd user manual is there just go through it.
Posted on Apr 24, 2009
I have cable internet and how would i connect the DGL-4500 wireless router to cable???
Turn the cable-modem off.
Turn the router off.
Use an Ethernet cable to connect the network-port on the cable-modem to the 'WAN' or 'Internet' port on the router.
Use another Ethernet cable to connect the network-port on your computer to one of the 4 'LAN' ports on the router.
Turn the cable-modem on.
Wait for its lights to settle-down to a repeatable pattern.
Turn the router on.
On your computer, you should have Internet access.
Feb 21, 2011 | D-Link DGL-4500 Wireless Router
Route multiple static WAN IP's to LAN IP's
the router has to be set up as a "pass through" device if your ISP has given you a static address pack.
Apr 20, 2010 | D-Link DGL-4100 Router (DGL4100)
Network connects without router. Install router
is your router powered? make sure your router is powered properly.
are you connecting your computer to the LAN ports? (the ones with a number not the one that say WAN? connect your computer to one of the LAN numbered ports and check to see if you get a green light on the front pannel. if you don't have green light, try a different port until, if you run out of ports and still no green light try a different cable.
have you by any chance disable your lan ports? I don't know if it is possible on your router to disable some ports, if that's the case is better to start fresh and simply reset your router by pressing a reset button for a minute while your router is getting powered and retest to see if you a green light on the lan port where you are connecting your computer.
if all this fails, it's very likely that your router has died. replaced accordingly.
Apr 04, 2010 | D-Link DGL-4100 Router (DGL4100)
I have a D-Link DGL 4500 wireless router. I have
If you don't see any devices connected in the DHCP client list on the router interface even when you are sure of the devices being connected, only a firmware update or a re-flashing of firmware can help. You can find the latest firmware available on the d-link support site. You can verify the model and version numbers and download the corresponding firmware. This is only fix.
Feb 05, 2010 | D-Link DGL-4500 Wireless Router
I have a DGL-4100 behind a Linksys DSL router 2 networks don't.
zSB(3,3) Installing a Two Router Network Installing a router to work as the second one on a home network requires special configuration. Do the following on the second router to ensure it (and the devices attached) function properly:
    1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode. Note that some home wireless routers do not support client mode; these must be connected by cable. Check your router documentation for details on its client mode configuration support.
    2. Check / change IP address - Most home network routers use a default IP address setting. Often, these default IP addresses will not work in a two router environment. Check the second router's IP address value and reset it if necessary to work within the valid address range of the first router (and to not conflict with any other device on the network).
    3. Disable DHCP - To avoid IP address conflicts between all of the devices on the home network, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
Instead of adding a second wired router to an existing network, consider adding a network switch instead. A switch accomplishes the same goal of extending the size of a network, but it does not require any IP address or DHCP configuration, greatly simplifying configuration.
Oct 10, 2009 | Computers & Internet
How do i hook cables to download new firmware into my dgl-4500 from computer to router
  1. I assume you downloaded the newest firmware (version 1.21NA) from this site.
  2. Save or move it on your desktop so it's easier to find.
  3. Connect your router to your computer with an Ethernet cable.(If you're not sure what it looks like, see here.)
Do not upgrade the firmware over a wireless connection!
On the same page, look at the FAQ's. there is an entry called "How do I upgrade the firmware on my DGL-4100/DGL-4300/DGL-4500?" It is a description of the upgrade process itself and will walk you through the steps.
I'm just amazed that they miss a really important warning. Do not unplug your router or close the browser on your computer until this process is finished. This can render your router useless and you will have a nice, expensive doorstop.
When the upgrade process starts, go have a coffee, do your dishes, whatever, but: Leave the router and your computer alone! Wait until the router's reboot is completely finished.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 09, 2009 | D-Link DGL-4500 Wireless Router
D-Link DGS-2208 only works through Hub uplink but not router?
i think it it ehternet cable problem.
when u connect switch to swith it is twisted pair but when u connect router to switch then straight.
Dec 31, 2008 | D-Link DGS-2208 8-Port Gigabit Ethernet...
Oct 02, 2008 | D-Link DGL-4100 Router (DGL4100)
Dropping about half rx packets
proably that bad roghter not best best is linksys made by cisco ther new one n so fast 20 times of any others ok cheak online for yours see if u have a frimware or updates avb for that unit from ther site ok half duplx 10 mb sec still super fast then any network can offer u thx nick
Feb 06, 2008 | D-Link DGL-4100 Router (DGL4100)
D-Link DGL-4100 Router (DGL4100) Logo
51 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
