Question about Cartier Watches
I just got a cartier ballon bleu and cannot adjust the date when I pull the crown out 1 notch.
    Genius:
  • 1,970 Answers
Mcdevito75 Here, It"ll take some practise but you should be able to pull the crown out to the first position to set the date. Carefully place a finger nail under the vrown and lift.
Posted on Sep 01, 2010
I everyone I got a cartier ballon bleu automatic. however, I cant set the date as I can only move the crown one notch in stead of two
The second notch is harder so you don't alter the wrong function. Slide your thumb nail under the crown.
Jan 15, 2016 | Cartier Watches
How do I wind a Cartier ballon blue watch ?
more than likely it has a screw down crown. Turn the crown towards you to release it from the case tube then wind it forward. Make sure that you tighten the crown when finished winding it or you will get water into the watch.
hope this helps, gabe.
Oct 22, 2014 | Cartier NEW CARTIER BALLON BLEU LADIES...
How do i wind a Cartier ballon bleu watch
your watch is quartz that means its battery operated and needs the battery replacing
Oct 18, 2014 | Cartier W6920011 Watch Mens Ballon Bleu De...
I need to change the date on my Cartier Roadster (back 2 days). How do I do that?
Thank you for contacting FixYa.
  • Pull the crown of the analog/date Cartier watch and rotate it clockwise or counterclockwise until you see the date advance in the display window at about 1 a.m.
  • 2 Use the quick date set method by rotating the crown counterclockwise after reaching 1 a.m. until the hands reach 7:30 p.m. Then again rotate the crown clockwise back to 1 a.m. Repeat the procedure until the correct date is displayed.
  • 3 Adjust the date forward or backward 12 hours if your Cartier watch changes the date at the noon hour.
  • Best regards. Jewel
  • Sep 13, 2010 | Cartier Roadster W62016V3 Wrist Watch
    Citizen eco-drive BM8084-58H: I cannot change the date/day on the watch moving the crown.
    mcdevito75 here, The crown should be a 2 position crown, try this, pull out the crown as if to set the hands, rotate the hands, (adjust the time) around the dial until you have the right day, Now! push the crown in, Now! slip your finger nail just under the crown and lift the crown to it"s first notch or position, this should allow you to turn the crown and adjust the date, when at the date push the crown back in and your done.
    Jun 28, 2010 | Citizen Corso Eco-Drive BM8084-58H Wrist...
    Setting time and date on my Cartier Pasha watch.
    Do not be so afraid. Unscrew that big crown fully, pull off and then you will see the real setting crown(quite small one), called an underlayed crown.
    That little chain is hard enough to withstand your pulls, unless you are drunk. :)))
    When you get that small crown handy- you can set the time and all the features.
    If the small crown is not moving, your watch is rusty and you will need a proper watchmakers help.
    Don't forget to rate, please.
    Jan 11, 2009 | Cartier Pasha 32MM WJ111156 Wrist Watch
    How to set time on cartier chronoflex?
    to set the time and date of cartier watch , full the crown at half setting possition then wind it until the date move push the crown to the normal possition then full the crown twoo times to time setting possition then wind it again until you search the correct time,fush the crown to the normal possition after setting,
    Aug 24, 2008 | Cartier Watches
    Set up date
    good evening ! pull the crown half and wind it to set the calendar ! .good luck ! .
    Jan 28, 2008 | Cartier Pasha W3014051 wristwatch
    Set date on Cartier Tank Francaise Chronoflex
    1. click the top button
    2. click the bottom button to reset the timer
    3. pull the crown out all the way
    4. twist the crown forward hard and fast for a few seconds. The minute hand will start advancing very quickly.
    5. when the desired date and time is reached, push the crown back in place. If you missed the time, pull the crown back out and twist backwards. The minute hand will move slowly in reverse. If you twist hard and fast, the minute hand will start spinning in reverse again.
    Oct 14, 2007 | Cartier Tank Francaise W51001Q3 Wrist...
    Watches Logo
    587 people viewed this question
    Top Cartier Watches Experts
    Jimmy Accardi
    ray gallant
    Are you a Cartier Watch Expert? Answer questions, earn points and help others
