Question about Kenmore 24032\24036 Top Load Washer
My kenmore top load washer works well, however when the spin cycle runs...the water drains but the clothes are still soaked. It sounds like it is spinning (but Im not sure if it actually is) and there is a burning smell afterwards. Please help......
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 01, 2010
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Washer works on every setting but does not spin on spin cycle
IF ITS A TOP LOADER ITS POSSABLE YOU HAVE A BAD CLUTCH IT A FRONT LOADER YOU MAYBE USING TOO MUCH SOAP
Jan 12, 2010 | Kenmore Washing Machines
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
GE WBSR3140D
I have the same problem. The water drains, but I have no spin leaving the clothes soaked. I get a humming sound and thats it. The rest of the washer works fine. Any help would be great.
Jan 13, 2008 | GE WBSR3140D Top Load Washer
Rinse cycle spinning... clothes still soaked
It sounds like your washer is not going through it's neutral drain. After agitation, your washer should pause and drain for around 90 seconds to pump out the water before spin. Check this out by starting a wash with a small screw driver holding the lid switch down. This will allow you to observe whether or not it's going through it's neutral drain. If not, it's a transmission problem. The trans is covered under warranty for 5 years. You may also want to check the pump to see if it's gunked up. Catriver..post back.
Dec 04, 2006 | Kenmore 24982 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
107 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
