Question about Brother Multi-Function Center MFC-3360c All-In-One InkJet Printer
Sending faxes when i try to send a fax it dials and tries to send, but several seconds later it says 'disconnected' on the screen. i have checked the fax and telephone lines and we are still able to receive faxes
    Genius:
  • 1,224 Answers
There line could be disconnected and the machine is telling you did you try a known fax number that is good try a fax there
if that didnt help your fax just needs a little time out unpluged to reset itself
Posted on May 10, 2008
What does transmission report cdoe NG290000 mean on a Sharp MXM363n MFP When trying to send a fax?
My recommendation would be to hit the speaker button when sending a fax to hear why your fax wont go through.
When you hit speaker you should have a clean dial tone, then when you start dialing and the tone stops make sure you don't have any static or noise on the line.
There are several reasons you might get a NG error. One is the fax line you're trying to send to is busy. Maybe it's a phone line not a fax you're trying to send to. Maybe you need to dial a 1 or 0 for long distance, maybe your fax line has noise on it.
Using the speaker can help troubleshoot what the problem is.
Jun 12, 2014 | Sharp Mx-M363n Copier, Printer & Scanner...
Cant send or recieve fax
Might be silly question but is it setup to auto transmit and receive? And have you tried to operate it manually? + take out the inline filter fax machines operate on volume'db' to soft and it can't hear, to loud and it can distort sound.
Dec 28, 2013 | HP Office Equipment & Supplies
How To Enable DTMF Digits on AR_M_280N Fax machine??
have you tried adding * 's they add a pause between numbers. You may have to add several, but that will put a slight delay in the dialing.
Jul 23, 2010 | Sharp AR-M280N Copier
All of sudden the fax component will not send or receive. Checked phone jack with plugging in phone and getting dial tone. Lights up/scans/ tells you to dial number but than nothing
Is this HP Printer ?
Disconnect the power cord from back of printer ( while printer is on )
while holding power button printer - connect the cord.
Under Setup - Advance Fax Settings - Turn off ECM
Under Setup - Fax settings - Reduce the Fax Speed to slow
try to send fax.
Jun 19, 2010 | Office Equipment & Supplies
My fax machine is not sending faxes but will recieve faxes it copies the pages to send then dials but once it connects it drops the call and gives a error message on the screen then tries to redial a...
Reset all settings of fax to factory defaults.
For that press menu button of printer and enter in fax settings reset all settings to defaults.
Then restart printer.
Also change phone line cable Then check.
My chat session is disconnected because of power failure .
Let me know if you need further assistance.Thanks.
Nov 20, 2009 | Lexmark X8350 All-In-One InkJet Printer
I can't send faxes, the screen says telephone. It
You may need to dial a prefix prior to dialing the phone number you're trying to fax. It could be as simple as putting a number "1" prior to dialing the number.
Jun 26, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
No answer when sending fax
The receiving fax machine never answered. Maybe their fax machine is set to MANUAL or is disconnected.
It's not your fax machine that's the problem.
Jan 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Sending fax
If you sending the fax over the memory, fax can scann doc. while dialing, or in the same time, but if you sending directly (on-hook dial) fax is sending the document while beeing reeded.
You may try to check the phone lines, browse the documents before sending,clean the original document feed rollers,...
if fax sudenly stops and wrinkle the orig. documents there is problem in scanner area
Jan 16, 2009 | Canon FAX-JX200
5610 issue
dial 9 then pu in 4 to 6 ",,,,,," then the number.
old fashion fax method, don't knock it, it works
Dec 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
Brother Multi-Function Center  MFC-3360c All-In-One InkJet Printer Logo
70 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
