Behringer part number Q05-14306-02470 Power IC board for LX1-112
4 Suggested Answers
robotek
  • 1512 Answers
SOURCE: Behringer PMX 2000 Amplifier
Hi aliciacarol,
The best place to go to get parts for Behringer parts I have found is straight to Behringer themselves, or an agent nearest to you. They are generally inexpensive to buy, and delivery are better than most. Steer your way to your nearest agent to you from the map . If you have any troubles, feel free to get back to me here. Good luck, thanks for using FixYa
regards
Graeme
Posted on Feb 29, 2008
  • 1894 Answers
SOURCE: Behringer Vintiger GM110 guitar amplifier Output pcb board
best idea is to buy a old one from ebay and use the board alone from it
Posted on May 23, 2008
  • 5603 Answers
SOURCE: I have a behringer pmp 880s powered mixer it has a
Please note that there are many chips in the Behringer devices and we can't guess what the chip might be since we have no idea where it is in the unit.
HINT: There are MANY circuits in common in the lines of music equipment. See if the circuit board has a part number as well. The board may be in common with other PMP boards.
Also note the chip location, such as IC12 and also tell the type, Thru hole or surface mount, and the number of leads and ANY number on the chip.
Posted on May 25, 2010
Ic burned
which ic burnt? if in the output (amplifier) stage it is probably a transistor (or pair) that went out. you will also need to replace the biasing resistor and diode. if in the input/preamp stage any general purpose 8 pin op-amp will work. Be careful when soldering this unit, it has a multi level circuit board. If this unit is out of warranty (over 2 years old) It will probably be more economical to purchase another unit imo. good luck.
Mar 22, 2014 | Behringer Pmp6000 Powered Mixer 1600w 1600...
You should be able to get a diagram from the company itself and the circuit board can either be purchased from the manufacturer itself or they can tell you who to call.
Here is the manufacturer's number
BEHRINGER USA beusa_t.jpgBEHRINGER USA Inc.
18912 North Creek Parkway, Suite 200
Bothell, WA 98011
Tel.: +1 425 672 0816
you can also try their online support at
http://www.behringer.com/05_support/webform_support.cfm?lang=ENG
but I would just call them, it would be much easier
Let me know if you need any further help or if they couldn't help you and I will let you know who else might have what you need.
good luck
May 23, 2008 | Behringer Audio Players & Recorders
Tda7293 IC in behringer b215a keeps blowing, whats the cause?
Problem in the part of the power supply that feeds the tweeter amp. Fix the power supply and epoxy the board where it needs to be epoxy. Best of Luck! Serge Lavallee.
Dec 19, 2013 | Behringer Eurolive B212A Speaker
Behringer inuke 3000 goes into protection mode when turn on. What is the problem?
Might be that a simple screw is loose or temp protector, but often the mute/ power off with these simple units is done with a capacitor and resistor, there would be the first thing to watch, just check which ic regulates the the power on/off mute ic
Sep 10, 2013 | Behringer iNUKE Series 3000W Stereo Power...
Behringer EUROLIVE B1800D PRO Active 18" Sub The power comes on Limit LED flashes then shuts down over and over
I had same issues with mine. Check T1, T4 T11 and T7 on Crossover/amp pcb pcb part number is P0981 It is blue in color. These are the output Mosfets. If they short the protection circuit causes unit to cycle into protection over and over. ALSO if they are shorted I would suggest replacing the Gater drive IC IC3 for T1 and T4 IC 11 for T7 and T11 as this is the main IC that drives these MOSFTETS . Here are the part numbers T1, T4, T11 and T7 are type IRFB4227. The IC in mine was type IRS20955 ( Note: this is no longer made by IRC as they had issues with them shutting down and not working correctly, the replacement is IRS20977) good luck.
Sep 11, 2012 | Audio Players & Recorders
How do i get parts for behringer b215d my power ic is burn out
Regards, urgent help.
I have a powered speaker Class D, and the PWM isdead. change the IC 3525, is controled by a NE555 which is shutting down. works when connected to a higher voltage 150v, but turned it off, I think by overheating. I already changed mosfets, and ICs. I think that may be some component failure is triggering the protection, someone could help me. I'm a musician and I depend on this car for my livelihood. Thanks
Jan 06, 2012 | Behringer B215D Powered Speaker (550 Watts...
I need a circuit board for a EP4000...
If the board has not been burned up, one should troubleshhot the bad components.
If you need to replace it call Behringer at 1-425-672-0816. Have the board number including any revision number to get the Behringer actual part number. They will give you and incident number as well for you to call FullCompass who distributes the spare parts now. You can find FullCompass phone number via Google.
Dec 13, 2010 | Behringer EUROPOWER EP4000 4,000-Watt...
I have a behringer pmp 880s powered mixer it has a blown IC chip In need the part number.
Apr 24, 2010 | Behringer EUROPOWER EP2500 Amplifier
For Behringer B300 where is the ic 7815 and 7915
Test the regulator chips FIRST before ANY replacement. These chips are very reliable and the problem is LIKELY elsewhere.
The 7815 and 7915 ar 15 volt three terminal regulators in TO220 style packages. Three leads. The 7815 is plus 15 and the 7915 is minus 15.
CAREFUL as the input and ground pins are in different order between the two.
FIND the specs and picture with Googling the numbers.
These chips will be soldered in AND MAY be screwed or clamped to a heatsink OR just standing up from the board.
Oct 20, 2009 | Behringer B1520 Pro Eurolive 15" 2-Way...
Hi aliciacarol,
regards
Graeme
Feb 23, 2008 | Behringer EUROPOWER EP2500 Amplifier
 Grubhead
Grubhead
