Question about Refrigerators
I have had my SANTO 75438 KG just over a year for the last 4-6 months I have to remove the large salad/vegetable container every morning to remove the layer of ice that builds up on the floor of the fridge, the drain hole is permanetly iced up also the ceiling and the back of the freezer is thick ice. We had an engineer in via John Lewis from service force he spent 1-2 hours removed the caseing on the ceiling and back of the freezer and removed ice build up on the fan and drain outlet, he said if this occured again to go back to the store within hours it the same problem returned I phoned John Lewis they insist that service force return next week so I wait for the outcome of this visit. this frige/freezer cost £895.00 and continues to have problems. Anita Daly
5 Suggested Answers
  • 1462 Answers
SOURCE: ice build up under the freezer drawer
drain is blocked. remove back panel inside freezer and melt the ice off at the bottom with a hairdryer then follow up with hot water till drain flows freely. if fault reoccurs, then you may have a fault with the defrost system
Posted on Jul 06, 2008
arikrom
  • 528 Answers
SOURCE: PDS18SBMRBS model GE Profile fridge. The fan
the heater unit might be weak and usualy it is a hlogen light that need to be replace , so the defrost will be better
Posted on Jan 02, 2010
machinetech7
  • 1344 Answers
SOURCE: recently noticed ice accumulation in
You have a clogged drain. Usually I remove the ice, take a screwdriver and tap it into the drain hole. Then I pour hot water down it until I see that the water is draining all the way out.
Posted on Oct 31, 2010
SOURCE: Whirlpool fridge AMB 575 KG around 14 years old
I had the same problem, remove front cover at front bottom of fridge. Clean the fan and air ways.
Posted on Jun 18, 2011
Can you freeze cucumber salad?
You can freeze anything. but cucumber is 99.8% water, and anything with so much water does not freeze successfully. Instead of the cucumber being white, it will go clear, and also because the ice crystals expand inside the cucumber, it will become mushy. Any oil based dressing would be fine, but a mayonnaise dressing will split.
So short answer, no you can't. I am a trade chef with 45 years in the trade :>)
Dec 11, 2016 | Refrigerators
Is Radish Vegetable or Fruit??
Radish is a vegetable. If you want benefits of radish check out: Top 10 Health Benefits of Radish Inlifehealthcare
Jan 27, 2016 | Home
What are the benefits of radish??
Some of the benefits of radish are:
1. It acts as a powerful detoxifier that helps in purifying the blood, eliminating toxins and waste.
2. It is also helpful in curing jaundice because it removes bilirubin.
3. Radish helps in digestion, water retention and fixes constipation in our body.
4. It is useful in removing ******* disorders.
5. Radish is very filling and thus it helps in weight loss.
6. Radish helps in increases the efficiency of the metabolism in our body.
Jan 27, 2016 | Miscellaneous
Electrolux side by side refrigerator water not dispensing
Hello - I would suggest checking that the water valve is completely open (usually located on the back of the unit). When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. A clogged water filter or a blocked supply water valve may also lead to no water to the dispenser.
Oct 14, 2012 | AEG Santo 7085 KG Side by Side...
Vegetables and salad materials icing in vegetable compartment
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Mar 29, 2011 | Westinghouse Refrigerators
Water appearing in the refrigerator and collecting on the back of the shelves as well at the bottom under the vegetable and fruit containers.
could just be condensation,which is normall,have you put any uncovered/warm/food or salad/fresh fruit in lately,these all add to the"problem"there is no "fix "other than kitchen tissue under the salad /fruit drawers,and throw away once a week.fridges are not frost free.(condensation in freezer is frost)
Apr 01, 2010 | Refrigerators
AEG SANTO No_frost refrigerator beeps with 5 sec freqency
We have the same fridge, and I could not find my model either!
The label is hidden on the bottom of the top part on the left side, you need to take the veggie tray out to see it. I spent about 3 hours finding the model on the net, and in the manual it said where to look lol.
This mysterious model is the AEG SANTOS 3895-6 KG AKA S3895-6 KG productnumber 928405123-- last two digits can be 00-33.
We had the same problem, solution: press and hold the ON button for minimum of 3 seconds. The fridge switches off. Wait 10 seconds and repress the same button. That´s the quick fix.
To make it go away completely switch off fridge, pull out plug, and thoroughly clean the air vents on the back below using compressed air. After this the problem went away permanently.
Good practice to airclean every 6 or 7 months. You can find the manual for the S3895-6 KG on http://www.electrolux-ui.com:8080
Feb 20, 2010 | AEG Santo 7085 KG Side by Side...
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
