Question about Technics SL-1210M5G Turntable
Gain output is not equal on left and right I
Gain output is not equal on left and right I recently purchased my M5G and thought it was all fine untill I start recording with them. When looing at the wave form I noticed that on one of the deck the left output was not equal to the right. This worry was confirmed by noticing the gain difference when switching to mono on my mixer. Any idea? Thanks a lot
  • 52 Answers
Is there a balance (LR) for the input on your preamp?
Is there an anti-skating adjustment on the tt? That controls the lateral pressure on the needle. Read the manual.
try a different set of cables
Posted on Sep 01, 2010
I have an urban audio works 7 band equalizer. i have a spx pro audio amplifier and an alpine cd reciever model cde987. the equalizer is not installed. could your please tell me where to wire in the blue,...
INPUT: Yellow (left front), violet (left neg), green (left rear), Blue (right rear), Brown (right neg), Gray (right front)
OUTPUT: Front Left pos (green/red) neg (green), Front Right pos (gray/red) neg (gray), Left Rear neg (brown) pos (brown/red), Right Rear neg (white) pos (white/red)
dfsanchez@yahoo.com
Mar 14, 2011 | Car Audio & Video
Want to know how do you hook up an equalizer to my DJ equipment
An Equalizer (such as a 31 band equalizer) connects in line with the left and right outputs. You would take the left feed out of the desk and run it through one equalizer, and do the same with the right output.
The output of the equalizer then runs to your power amps. Most equalizers have a bypass mode so that if you decide not to run them you do not have to unplug them. Equalizers are made by a lot of different companies, but an example of one can be found Here.
Feb 28, 2011 | Audio Players & Recorders
Hi i trying to figure out how to wire up my rca's i have a pionner deck in on the back of it it has front output,rear output,sub output ,and also a audio output .now im trying to up it to a clarion eq that...
The "Front output" from the Pioneer deck would connect to the "Main In" on the Clarion EQ. I'm assuming that your Clarion EQ can only deal with one input, and will send the adjusted (equalized) signal out both of the outputs.
The "Front output" from the Clarion EQ should go to the "Front Input" on the 4 channel amp.
The "Rear output" from the Clarion EQ should go to the "Rear Input" on the 4 channel amp.
The "Sub output" from the Pioneer deck would connect to the Left/Right Input on the Epicenter. The Left/Right Output on the Epicenter would need a Y-splitter for each side, so that you could connect each amp separately. One suggestion would be to use one sub amp for both subs.
Feb 18, 2011 | Clarion Car Audio & Video
There is no output from the right side of rec out.The left side works fine
Most likley a simple fault on the phono connector and the board it's soldered to. Check for dry joints and cracks where the sockets are mounted.
http://stores.ebay.co.uk/methleykev
Sep 04, 2009 | Pioneer DJM-600 Silver Professional DJ...
No Right Front Speaker Output
Swap speakers over...check the balance isn't fully to the other channel...swap left/right phono cables over (if thats how your using it) other than that i would say is broke.
Easy way to check speaker cable/speaker... touch a small battery (like used in a remote) across speaker wires, you will hear and see the speaker cone move.
Aug 07, 2009 | Audio Players & Recorders
How do we hook up a roadmaster equalizer model number EA400N to a 1989 dodge ram pickup truck
First of all I would recomend that you consult your user's manual that should have been in the box when you purchased your reciever. Your CDR and MD in/out jacks should not be used for an EQ. Your EQ process should take place after everything else in the signal chain is completed and right before your final amplification. If you have no designated in/out for an EQ then you may have to find some other way of processing the signal. Perhaps a pre-amp may be needed in order to bring all of your signals together to then run through your EQ. Sometimes some amps have pre-out/in RCA jacks. These can often be used for an EQ.
Post further comments for more help.
Good Luck!!
Thanks
Jul 08, 2009 | Roadmaster Car Audio & Video
NAD 302 stereo balance problem
I would replace the output transistors of the bad channel and any very low ohm resistors associated with them.
Whilst youre in there replace the electrolytic caps in the power amp section. Caps are cheap and plentiful.
I dont know what the rest of the circuit looks like but there might be a need to balance the DC offset after replacing transistors.
matelectronics.com and audiolabga.com carry many good replacement transistors.
Dec 30, 2008 | Audio Players & Recorders
One ear
try using m5g on another channel if that solves it its your mixer if it doesn t then its probably the cable frm your m5g
Jan 26, 2008 | Technics SL-1210M5G Turntable
Hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Oct 15, 2007 | Audio Players & Recorders
Technics SL-1210M5G Turntable Logo
277 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
