Question about Altec Lansing Inmotion-IM600 (0021986954446) Docking Station
In need of a MH29654 battery for docking station. Where can I get one?
  • 10,515 Answers
Buy it from :-
http://www.bestbargainhouse.com/servlet/the-65/Altec-Lansing-im600-Rechargable/Detail
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 01, 2010
Need replacement battery for I-pod docking station Model#5084
I have a battery from my if-2 by Sonic Impact. My ipod connectionwent bad. Battery and charger available.
Jul 23, 2010 | Sonic Impact Technologies IF22 Docking...
Docking station for MX1000 Laser mouse not working
That docking station has a lithium-ion battery in it that supposedly never needs replacing. I'm wondering if the battery did go out on it and needs to be replaced. If there is now way to get inside of the docking station then you will need to get another mouse, cause you can't just get the docking station.
May 27, 2010 | Logitech MX1000 Laser Cordless...
Battery part no Mh29654 for iM600 speaker need to purchase a new battery. Proving to be a night mare to obtain as this has 3 wires with sq connecter.Model no McR18650 3.7v
buy a cilyndrical 3.7v battery,a bougth a onu with 3000mah. and use the conectors from your old one,they are built-in circuit take it apart and reuse it
Mar 02, 2010 | Altec Lansing Inmotion-IM600...
I have a T2+ remote sys and need a manual. as a start I need to know how to charge.
The remote comes with a charging dock, if you did not get this you can order one from RTI (952) 253-3136.
BATTERY AND DOCKING STATION
The T2+ uses a Lithium-Ion rechargeable battery. This battery does not exhibit any type of "Memory Effect" from being charged too often. Since the T2+ can safely be charged after each use, a docking station is included for convenience. If left out of the docking station, the T2+ will remain in sleep mode for 1 or 2 months before shutting down. At that point the battery must be recharged. The T2+ Docking Station can be placed on a flat surface such as a shelf or table, or it can be mounted to a wall using the mounting holes on the back of the unit. If the T2+ battery capacity is reduced to approximately one hour of remaining run-time, a low battery icon will appear in the upper left corner of the display The docking station LED illuminates to indicate a charge in progress. The LED will turn off when the battery in the unit is fully charged.A fully discharged battery will take approximately 2-4 hours to completely re-charge.The T2+ can remain in the docking station indefinitely without damage to the battery.
Jan 17, 2010 | Rti Technologies Rti T1 Remote Control
Casio exilim lens retracts wen u press to take pic
The battery probably needs charging. The camera will automatically shut down if the battery is going flat.
With the Exilim you need to make sure that you don't overcharge the battery by leaving it permanently docked in it's little docking station - this can damage the battery. There is an LED on the docking station which shows the status of the battery. Red is charging, green is fully charged - take it off the docking station.
Dec 11, 2008 | Casio Exilim EX-Z77 Digital Camera
Battery/docking station ac power
There is no manual way to switch from battery to AC, the machine or docking station should automatically switch between battery and AC. There is a power management chip inside the laptop that regulates the power and switches from battery to AC when plugged in. Some docking stations have a chip built into them to do this. Start by ruling out the power supply. Do this by undocking the laptop and plug it in using the power supply that is attached to the docking station and see if the machine is just running off of battery. If it is running off battery, then check the power supply with an ohm meter for the proper output. The output readings are on the supply. If you have two power supplies, and you know one works with the machine, try that supply on the docking station. If the power supply checks good, then I'm afraid the pm chip on the motherboard has gone out. You will need to take this in to have it professionally diagnosed, because it could be a replaceable component that works in conjunction with the pm chip. However, if it is the pm chip, then the motherboard will have to be replaced in order to fix it.
Jul 22, 2008 | IBM ThinkPad T23 Notebook
Docking station fror compaq Evo n610c
docking station for my old compaq armada did not "charge seperately" but did supply power to the pc through docking connector and not through the normal ac input, cant say if they have their own power transformers or not, till i go home and take my old docking station apart. Will the computer not power up when plugged in, it normally will run off ac power even when battery is dead or removed.
May 06, 2008 | Compaq Evo N610C Notebook
Battery/Docking Station
I have a working used one if you're interested. Google my username, and I can help out... ;)
Jan 11, 2008 | Casio EXILIM EX-Z1000 Digital Camera
Altec Lansing Inmotion-IM600 (0021986954446) Docking Station Logo
599 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
