Question about Honda Garden
HONDA 11 HP SMALL ENGINE (GX340) STARTS AND RUNS ABOUT 15 SECONDS AND QUITS. ALWAYS RESTARTS, BUT WILL NOT CONTINUE TO RUN.
  • 373 Answers
SOURCE: chrysler 3.3 vin r v6 mini van, starts then dies
Charlie. You have replaced the ECM on your van?.
Kedwin,, Your problem is, the computer on that 3.3 L.
Need to be programed with the VIN nember of your car.
The Antitheft System will disable the injectors due a incorrect VIN, Bucause the body computer is not recieve the correct pasword between 5 seconds after start up.
YOU have 2 options. 1 get a ALOHA Smith. some of they have the computer required to program ECMs.
The other option is: Get a new ECM from the dealer, They will program if ask for that.
NOTE:::::: Other way is . Put the body control module with the computer from the same car.
OK... I hope this work for yours.
If NOT letme know I can look for more information.
Thank you.
Posted on Jul 17, 2008
SOURCE: Katcher pressure washer w/ 5hp Honda Engine
pour a bottle of carburettor or fuel injector cleaner in the fuel tank, replace the spark plug and set the spark pluglug gap at 0.7mm. Replace the air filter element. Also change engine oil if necessary (mobil 10w30 synthetic.
Posted on Feb 03, 2009
skrbin
  • 121 Answers
SOURCE: Runs 10 - 20 seconds then quits-restarts on next trigger pull
Check battery maybe is old or not correctly charged.
Posted on Feb 16, 2009
  • 10865 Answers
SOURCE: Engine won't start . Pour gas in cylinder it starts then quits.
hi lou. your carbeurator is gummed up. It will need to be removed, soaked in carb cleaner for three hours and then rebuilt using the correct kit.
if you are not familiar with how to do this i recommend that u have it done by a lawn mower pro
Posted on May 28, 2009
  • 174 Answers
SOURCE: Honda GX340 11 Hp ..Runs fine until it gets hot , Cuts off and
Have you checked the oil level?
Posted on Jun 28, 2009
What RPMis the max torque
the chart shows figures of 10.7 hp-8.0kw with a torque of 19.5 ft/lbs- 26.4nm at 2500rpms ( max net torque)
the chart shows gx390 is 11.7hp (8.7kw) but the torque is the same as the gx340
you can get these figures from world. honda com or by going google and typing in--torque range of honda gx 340 motor at max rpms
10 hp engines running at 2500 rpms will be good for gensets of 5kw continuous out put as most makes run that size engine
Apr 20, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
RUNS AND QUITS
You could try replacing the ignition coil. If it's failed, then it may run ok for a few seconds, but as it heats up it fails. Trying to start again immediately will be too soon for the coil to have cooled down. Leave it a few minutes to cool down and it will run again, but only for a few seconds again.
Hope that helps
Jan 03, 2014 | kawasaki 2011 Teryx 750 FI 4x4 Sport
Starts, idles and runs but quits after a few seconds of cutting
Check the air cleaner and muffler for plugging. One screw adjusts the idle stop (idle speed) position and the H and L jet screws set fuel mixture for high speed and idle speed mixture respectively. Turn both jet screws CW to stops (lightly) then back each out CCW 1-1/2 turns. This is a basic setting and should allow the engine to start and run. Start the engine and allow to warm up. Pull the throttle full on and adjust H CW until the engine starts to speed up, but 4-strokes. Correct adjustment is when the engine 4--strokes running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW until the engine idles fairly well, but allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
May 17, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Will a honda engine gx 340 11 hp engine fit
no it will not fit unless some modifications are made
Sep 13, 2009 | Garden
FIRST...check the engine oil level. Some Honda engines have an oil sensor that shuts off the spark if the oil is low. This would also explain it shutting down when it get hot. Check the manual to see how to tell if the oil level is correct. Also, the oil should be brown and transparent, not black. It may need changing. Post again if this doesn't help :-)
Jun 01, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
250 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
