Question about Makita 12 Volt Cordless Drill/Driver Kit
Led light does not go off after use on a BDF 452 cordless drill?
  • 90 Answers
Not sure what the solution is but if you decide to open up the drill be very careful. all the guts only go in one way or the case won't close.
Posted on Sep 01, 2010
Black decker cordless drill ldx120 runs for a second and shuts off, battery fully charged and the led light comes on and is bright.
The brushes on the motor may be worn . The battery may have several bad cells in it. The led lite only needs 2 volts for full brightness.
Jan 17, 2014 | Drills
Led light comes on but driver will not move
sounds like your brushes need a look at remove to see if broken or worn and replace them
Apr 23, 2012 | Hitachi WH12DMR 12V Cordless Impact Driver
Hi have a makita bhp 452 drill under a month old changed the battery twice still comes up with red green light?
take it back for warranty replacement, I would also take the charger to ensure it is not at fault.
Aug 03, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Have a 15.6v cordless drill - both batteries charge up to ~6v and no more; the red led is on - are both batteries the problem? this is the second charger - drill does not get used very ofter - model of...
See if you can put a volt meter on the metal contacks of the charger to see what voltage it is producing. If you have a friend who has the same drill have him try to charge your batteries and then measure the battery voltage.
Mar 14, 2011 | Craftsman 14.4 volt Cordless Drill/Driver...
Drill will not screw and reverse out, just the three LED lights come on
Check manual what does it mean. If you don't have it, it can be battery problem in case of cordless tool or worn brushes (no matter if it is cordless or corded).
Oct 10, 2010 | Hilti Drills
How do i disengage the torque controller on the makita bga452
The bga 452 is a 4 1/2 inch angle grinder. I take it you have a cordless drill with clutch> You can disengage it by turning it all the way to drill, it will no longer clutch, the clutch is for driving screws, they won't strip. The lower the number the lower the torque. Hope this helps.
Apr 27, 2010 | Garden
I have a 18 Volt Makita drill , model # BDF 452 which I've used only 3 or 4 times . The last time I used it , I could not remove the drill bit . The chuck will not turn/loosen to release the bit . Any...
oh I hate when that happens. ushally its due to not being lined up right inside the unit. happens with my cheaper drills more so then not.
I ushally just secure the bit into my vice, and then tap the the key with a hammer to loosen the threads..
sounds like she might need a bit of oil I ushally use air compressor oil just a couple drops work for me.
Aug 13, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 12 Volt Cordless Drill/Driver Kit Logo
88 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
